Question about Dell XPS M1530 Laptop
Hi My Dell M1530 doesn't start up The battery is fully charged, the power cord is working good(the light is on) but the laptop doesn' give a sign that is connected to power
  • Mariano Pedro Bernacki
    Mariano Pedro Bernacki May 11, 2010
    Hi, what operating system are you using? What is the maker and model of your laptop's motherboard?
  • 2,567 Answers
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Posted on Nov 19, 2009
My Dell XPS M1530 replaceable battery showing warning sign on the battery icon.
Try to see if there is a BIOS update for your laptop. The last version is A12. That sometimes will fix the problem. If not then it is most likely that the internal charger is built into the motherboard of the laptop is starting to fail. You would have to replace that part or most likely the entire motherboard.
May 04, 2017 | Dell XPS M1530 Notebook
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
I have hp pavilion dv6000 laptop, problem is that only 10 minutes is working batary after that again i have to connect power
Hi, It sounds like the battery has come to the end of its life and you will need to replace it.
Most laptop batteries in my opinion only last 18months to 2 years before they need replacement, this is common to most all laptops.
hope this helps.
Feb 14, 2011 | Computers & Internet
Battery installed power shows but not charging battery, new battery and charger. thanks.
Hi
Its a common issue for DELL Laptops usually if the battery and charger are working fine the culprit is the motherboard. If its still under warranty have them replace the motherboard and it will be good as new.Thanks
Feb 08, 2011 | Dell Inspiron XPS Series Notebook: XPS...
My dell inspiron 6400 battery is not charging. The power meter shows that the laptop is pluged to AC power, but the battery is not charging. I have also noticed that the battery charging led light is not...
Hello there:
what you can try to do is to remove the battery and unplug the power cord from the computer
now inspect the connections on the battery and the computer and clean both of them with a q tip and some rubbing alcohol make sure that it is really clean and let dry
now press the power button and hold for 30 seconds
now insert the battery and the power cord and start up the computer and see if this helps if not i would have the battery tested to see if there is a dead cell if so you will need a get a new battery. ok
hope that this is very helpful
best regards michael
Oct 23, 2009 | Dell Latitude D600 Notebook
My laptop is plugged in the green light on but isn't charging.
Please try to see your power cord connector and try to see if it is working.
Thanks
Aug 13, 2009 | Dell XPS M1530 Notebook
My laptop xps 1530 battery not charging
The battery is stationary but the cord is not, so I would say it is the cord. Go top a good store that works on them and ask to try it before you buy it. A new power supply can run $60.
Jul 19, 2009 | Dell XPS M1530 Notebook
Battery charge issue with Dell XPS M1530
when the battery is fully charged the circuit inside the laptop, automatically. stop charging to increase the the life of the battery,,, thank you,, plz rate me.,,,
Jun 28, 2009 | Dell XPS M1530 Laptop
I have a Dell XPS M1530 and it will not power up. I push the power button and the blue light goes on for 3-5 seconds and then goes off. Power is entering laptop and battery is fully charged but nothing...
this is either a motherboard, AC or battery problem. Isolate it by removing all attached devices, then emove the battery and power on the computer with just the AC adapter. If that does not work, remove try to use another AC, and another battery. if using another AC and another battery does not work, run the diagnostics on the dell laptop. press and hold the FN key, then press the power button. see if that will give you any error and take note if any of the lock lights will come up and/or blink.
Apr 08, 2009 | Dell XPS M1530 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell XPS M1530 Laptop Logo
307 people viewed this question
Alun Cox
