Question about Siemens SL75 Cellular Phone
My moblie sl75 gets hanged when i press SOS,but demo is ok.It happened when my phone memory is fully filled.What to do?
Cannot open music or podcast. Once open, will hang
You can try hard resetting the phone. It would erase all of the data in phone memory. It's advisable to remove the sim and memory card while you do this.
you can put *#7370* - Soft reset
Hard reset
Press and hold GREEN + RED + CAMERA when powering up.
Keep the keys pressed until you get the shaking hands. That should fully reset the device, with a lock code of 12345.
Aug 18, 2011 | Nokia 5800 XpressMusic Smartphone
Instruktions for mms.From sweden , halebop
Ok i did this yesterday and it works for sl75
go to this address
http://www.halebop.se/mobiltjanster/installningar/
type in your mobile number
press "vidare"
chose "simens"
chose "SL65" (yes this works with SL75 to!!)
press MMS
then you'll get a sms that tells you that the settings will be sent
when you get the settings, install them then restart your SL75 and your done!!
Nov 10, 2010 | Siemens SL75 Cellular Phone
My phone has frozen it self and it wont let me use my moblie unless its a sos call
I'm sure u'r phone is a multimedia phone if so then the memory card u use or inserted inside may have corrupted the phone. Try an eject the memor card and restart the phone. But there are no + effects then u've downloaded or u've put a corrupted file into the phone. Wat is need now isn't inputs of codes. Go to the nearest phone repair shop that the phone should be flashed it shall cost a little but I'm sure it will bring it back. Or u might download the softwre of the phone. If it's Samsung u can download samsung pc studio and scan the phone using a usb for possible viruses. But the idea for flashing is recommended. SEe yah any more probs meet me orace2010@live.com
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
Error code says press shutter release button again
I e-mailed nikon for this same problem. Their solution was to take out the memory card and press the shutter release button in the demo mode. To get to the demo mode you first need to go to custom menu/controls/no memory card?/press ok/ arrow down to enable release and press ok. Now you are ready to try solving this problem. Press the shutter release button to see if it will reset the shutter release button. I haven't tried it yet but it is worth a try.
Aug 25, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Hanging in the moblie kp500 with puk code
To get puk code you need to contact your phone service provider.
Jun 17, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
HP iPAQ voice Messenger Moblie 512
You need a new battery. This happens with litheon ion batteries after a while. Over the years my laptop battery went out on me after 3 years, my cellphone battery went out on me 2x's (different cell phones). It was all better when I got new batteries for them.
Jan 02, 2009 | HP 8710w Mobile Notebook
NOKIA 3110 CLASSIC RESTART PROBLEM
salam
restore ur mobile factory settings
apply only builtin themes of nokia
do not fill ur mobile memory and always leave space of 500 kb
delete ur notes and celender notes
do not apply heavy wallpapers
hope the answer of question
Sep 09, 2008 | Nokia 3110 Cellular Phone
In Use message
It sounds as if your unit is busy trying to perform a function and is loading RAM to its max. Unplugging the unit allowed the electrolytic capacitors to fully discharge and clear this RAM. It was only temporary because the unit filled up the RAM when you plugged it back in and when it did, the unit became inoperable once again. The problem is finding out what functions, or checks, the unit is performing to fill its' RAM. It appears to be a memory problem at this point. What is causing this to happen will take further troubleshooting.
Jul 13, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
UN Forwarding calls
Pick up handset, dial 710 then #, hang up.
May 29, 2008 | Panasonic KX-T7630 Corded Phone
Phone blocked
Dear Sir, I am facing big prblem I have siemens SL75 and I enter the phone security code wrong and it is locked now I have the IM of the phone how can I reopen it I need your help ?
Please, help me.
May 14, 2008 | Siemens SL75 Cellular Phone
Siemens SL75 Cellular Phone Logo
Top Siemens Cell Phones Experts
Computer Repairing
Computer Repairing
michael galang
Yoav Shilon
Yoav Shilon
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
