Question about Behringer F-CONTROL AUDIO FCA202 External Sound System
Need to increase microphone input sensitivity for Behringher MA400
    President:
  • 1,884 Answers
Click open the Volume icon in the system tray in the right bottom corner of the screen and up the slider on the MIC column. Not too much else there would be echo and back ground mush.
Posted on Nov 18, 2009
I have ax 496 Yamaha amplifier, can I connect microphone in this device?
There are two inputs on that unit. One is a MM input for a turntable and it has a sensitivity of 2.5 millivolts. The other is any line input and they have 150 millivolts limit. For more info read this: http://www.audio-technica.com/cms/site/214c5c52432bc79b/index.html
Now you understand how they are rated from the microphone perspective, you may be able to use the MM input.
Sep 16, 2016 | Yamaha Audio Players & Recorders
Need manual can't get sound to my stereo have audio red and black wired to aux input on stereo
You should be able to download a manual from the manufacturer's website.
The aux input is generally high impedance and low sensitivity, needing more than one volt to obtain good volume. If your supply is in the order of a few millivolts, such as provided by a quality moving coil microphone or a magnetic record pick-up it is unlikely any sound will emerge from the loudspeakers.
Matching the source to the correct amplifier input is very important and once the choice has been made most amplifiers of my experience, that particular input must be selected at the controls of the preamplifier.
If the amplifier is only provided with an auxiliary input you might need an additional preamplifier to provide the correct matching of source to input sensitivity.
Jan 03, 2016 | Audio Players & Recorders
How to play my acoustic guitar on my my jbl avr134 home sound system it does have a amplifier I want the steps for it plzz
An acoustic guitar, unless it is an electric type, will need to be played near a microphone in order to provide a signal for the sound system and the microphone or the guitar will have to be connected to a compatible amplifier input.
Impedance matching is not so important unless high quality is required but matching the sensitivity or gain of the input to the output of the source is important for optimum performance.
A moving coil microphone has an output of just a few millivolts and a crystal microphone can produce an output of around one volt.
Aug 10, 2015 | JBL Music
I usually can hear the phone ring through my headset but now it is not letting me hear the ring tone? Help!
That function is performed by the built-in microphone of the handset lifter. It gets it's signal from the speaker vibrations inside the phone. You want to make sure that the phone rings loud enough. If that microphone has gone bad, your handset lifter came with an accessory package that contains an external microphone that you can connect to the back of the lifter to increase sensitivity.
Good luck from Headsets Direct!
Mar 08, 2011 | Plantronics CS70 Wireless Headset
How to connect microphone to Yamaha RX-V365 as a PA system.
Home-theatre receivers don't have microphone inputs. If you want to use the receiver as an amplifier in PA system, you need to use some kind of mic pre-amp or a mixer with mic inputs.
For PA mixer is needed anyway almost every time and all mixers have at least one mic input (with a pre-amp). Mixers have line-level output(s), which you can connect to the analog input of receiver.
Using receiver as an amp in PA has advantage that you have 5 channel amp. When using high sensitive PA speakers (as oposed to less sensitive Hi-fi home speakers), you can get good performance with the power rating of receiver. You could even use 2 separate channels for subwoofers and 2 channels for satelite speakers - but for that you would need a receiver with 5.1 analog inputs and special device called crossover which would divide the output from mixer into low-frequency signal and high-frequency signal which you would then connect to the front and rear analog inputs. But with RX-V365 you can use only 2 channels with analog input
Sep 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Phillips microphone plugged into stereo input and cannot get it to work
The stereo input is not sensitive enough to amplify the small electrical current coming out of a microphone. You need either a mixer or a pre amp to do that.
Nov 27, 2009 | Philips PH62080 Uni-Directional Microphone...
BB 8310 : Increase microphone sensitivity
that is not possible to my knowledge as yet but try googling it and see
May 13, 2009 | AT&T Blackberry Curve 8300 Smartphone
Technical specifications needed for an Korg contact microphone CM-100L? Thank you.
The CM-100L Contact Microphone is a perfect compliment to any tuner that offers an audio input jack. The mic can be positioned to get a more sensitive reading, while allowing the tuner to be positioned for easier reading.
The jack is a 1/4" male phone connector.
that is on the official site...
Feb 19, 2009 | Korg DTR-1000 Microphone
Pcchips A13G+ motherboard sound issues
You may not have a choice. The jack could be loose or have a bad solder joint. If the microphone is "staticky" on this system but not on another, then increasing the volume will only increase the static.
You can try a condenser microphone. Condensers require their own power (battery) and output a MUCH higher signal. High enough for the Line-In jack.
If you are using the microphone for voice chat or internet phone or gaming or similar, I STRONGLY suggest a USB headset, such as you can get from Logitech. You wouldn't believe the quality difference.
Jul 06, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Im using a mic, but its looking for a guitar, how do I get it to find my mic
It shows a guitar for higher input level or you can set it to a lower level(more sensitive) - it will then show a microphone
Dec 21, 2007 | ElectroVoice RE2-410 Professional...
Behringer F-CONTROL AUDIO FCA202 External Sound System Logo
203 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Steve
Steve
Brett Duxbury
Brett Duxbury
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
