My kds50a2000 doesnt show no video and blinks 5 time red after a minute of it blinking green its not the bulbs or the fans. it turnes red after the tv does a click sound
  • 68 Answers
5 blinks is a lamp driver error the ballast is bad.
Posted on Nov 18, 2009
Tv dont power on green light flash then turns off red lights blinks 5 times
Had that problem and replace the lamp twice, I finally replaced the optic block.
It is quite involved to replace, if not technical get professional help.
Mar 21, 2014 | Sony KDS-60A2020 60" HDTV
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Apr 24, 2012 | Sony KF-42WE620
I have a sony kds50a2000 and it wont turn on at all. When i do try to turn on the green light blinks many times then its followed by the red lamp light blinking continuously and wont stop blinking unless i...
You should Google the model number with "problems" as there are several sites with good information on this set.
I would suspect this model does not have a color wheel but if it does it would be suspect number one.
Sets that use a wheel that turns at 12,000 rpm will fail. I would (if I was working on the set ) take rear cover off and try to localize where the sound is coming from) Likely: the ballast that powers the lamp will buzz sometimes when bad or lamp is bad.
Remove lamp and inspect to see it is not shattered.
A fan (one on the lamp) could cause this but rarely.
Look, listen, and do some research with Google.
last resort Call Sony with model number (expect them to tell you take it to shop--usual response)
Apr 09, 2012 | Sony KDS-50A2000 50" HDTV
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
KDS50A2000 Green light comes on briefly followed by red blinking light. 4 on then pause, etc. etc. Problem???
I tried this solution last night. had a similar issue. opened up the back panel and cleaned the fan. just for the fun of it, i tried to turn the tv on and presto. it works fine now and i probably saved a bundle. thanks!!!
Jan 25, 2010 | Sony KDS-50A2000 50" HDTV
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
My sony kds50a2000 failed lastnight. Bulb only?
There could be something else that caused the lamp to fail but if it has 6 to 8 thousand hours on it that is the expected life and it is not uncommon for a lamp to fail this way.
Mar 10, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
My tv is blinking red in the power indicator 4 times on my KDS-50A2000
I had the same problem. Red LED blinking 4 times. This error means that one of the fans is NOT spinning! To check.... unplug the tv.... turn the TV around to a well lighted area so that you can see the fans in the back... plug the TV in and turn it on. Watch for the fans in the back... and see if they are spinning. If not... that is the reason why the TV will not turn on! In my case, the fan next to the lamp was stuck for some reason. I removed the the cover of the TV from the back... and cleaned the fan, made sure all connectors to it were properly connected... and viola! The TV is perfect again! Enjoy!
Feb 05, 2008 | Sony KDS-50A2000 50" HDTV
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
