Question about ASUS Intel 440BX Chipset P2B Motherboard
Get blue screen when trying to install windows xp on an asus p2b motherboard I keep getting error code 7 and it stops install process
  • mike72c Nov 20, 2009
    I had the cdrom as first boot device. After reading all the fixes out there about installing xp I checked my ram chips again. I dont know what was wrong but apparently they werent seated well enough. After I re inserted the ram I was able to load xp on the fresh hard drive with no problems. :) thanks for all the help guys Appreciate it.
  • joecoolvette
    joecoolvette May 11, 2010
    In BIOS Setup, do you have the first boot device set to CDROM? Yes? Do you have another CD drive? Try it.
    Problem Solver:
  • 16 Answers
Hi this is problem of operating system or RAM not motherboard.
you have install os again & check your system RAM
Posted on Nov 19, 2009
Dell optiplex 780 i wanted to change from windows 7 to xp blue screen appears how to fix
You are going to need to start your computer in safe mode and find the XP drivers that will work for your motherboard manually from the web (Assuming that there are any created for XP for that board). That blue screen you keep getting is because you don't have the correct driver loaded for something on the motherboard that it needs to boot correctly and your XP install couldn't find it on the web to install automatically.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking".
Now start looking for your drivers here:
http://www.dell.com/support/drivers/us/en/19/Product/optiplex-780
Aug 17, 2012 | Dell Computers & Internet
I can't load Windows xp. Get this error with blue screen of death irql_not_less_or_equal I had windows 7 on it but not all of my devices would work. Win-7 loaded with no problem . So I put xp in format and...
Guest
In regards to getting the "irql_not_less_or_equal" BSOD this can be related to several things. You could be having a driver problem or a hardware related problem. To know exactually what your problem is we need to look at the stop code you are getting as well. The link below will show you what number I need to see exactually where your problem is.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Note Since you have gotten Windows 7 to install most likely the issue is driver related. So the thing to look at with your Windows XP CD does it atleast have SP2 as a part of the install. If it does not you may not have all the chip set drivers that the motherboard needs.
Issken
http://www.fixya.com/users/issken
May 13, 2010 | Intel DP45SG Motherboard
Asus p5q pro with intel quad core 9550 end so win 7 64 bits i have a lot o blue screen
Blue screens are usually hareware errors...but can aslo be caused by software issues so if you have installed anything new even like your windows 7 or any other new programs..make sure you have the windows compatible to your motherboard....and if your motherboard supports your 64bit system on windows 7 just make sure you have the right drivers installed for it..check that you have no viruses ect.. aso make sure your memory is supported and maybe clean them out by blowing out dust ect...let me know what happens so i can try help more pls ...
Jan 05, 2010 | ASUS P5QL PRO Motherboard
I have asus m2n-mx mother board amd 3600+... i have tried installing vista n windows7 in both i can run for some time later i get a blue screen is there any specific driver to be installed to stop this...
Yes, you are right, It is possible that your motherboard cannot support Vista O.S.. Reinstalling Windows XP
O.S. will prove it. If XP works, you 100% right.
Nov 14, 2009 | ASUS M2N-MX Motherboard
BIOS jumper settings of a ASUS P2B-VT motherboard
I found a source with a similar model. the exact one not available as the board was a custom OEM version. Try this link;
http://dlcdnas.asus.com/pub/ASUS/mb/slot1/440bx/p2b/p2b%28pcb1.02%29.pdf
Sep 07, 2009 | ASUS Computers & Internet
I recently tried to install a new WD320Gb HD and windows XP won't load. I loaded it to the drive from another computer and Windows won't successfully boot up. I get a Stop: 0x0000076B (0xF7946640,...
You installed the 320GB drive into another system & installed windows XP. Than removed the drive & installed it into another computer!
All of windows internal drivers for the first install will not function in the second. (Windows XP is going nuts).
You have to do a fresh install while in the system you want to keep the drive in. This is why your getting the stop errors & blue screens.
You must have a reason of why you did not install the 320GB drive into the second computer for the XP installation?
Care to provide the why?
Mike
Apr 26, 2009 | Biostar M7NCD Pro Motherboard
Error reading motherboard cd rom
i would go to the asus website and get the drivers you need from there.
Jul 29, 2008 | ASUS Intel 440BX Chipset P2B-F Motherboard
Asus P2B-N With Win 98 IRD problem
Try this, although not 100% sure it's the answer to your problem but it's worth a try. www.actisys.com/files/win98sir.doc Apologies in advance if no good to you
Nov 29, 2006 | ASUS Intel 440BX Chipset P2B-N Motherboard
ASUS Intel 440BX Chipset P2B Motherboard Logo
169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
