My wire less is not connecting,tried to hit
My wire less is not connecting,tried to hit repair and a few other things and it will not work ..its a belkin
  • 358 Answers
The first thing that I would advise you to do is,
Uninstall the WiFi Adapter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wifi Adapter).
After this, Press your Wifi button on the system and ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you don't know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Posted on Nov 19, 2009
I have a laptop that I sign in with a password and then get a blue screen.
There are a few things which could cause the problem that you describe. However, as your laptop is less than a month old go back to the vendor/shop where you bought it and get them to sort it out. Take your receipt with you.
You have an automatic 12 month warranty with a new item. Don't try and do anything yourself as this may invalidate the warranty.
The onus is on the vendor. They either have to give you a new unit, refund your money or repair/refurbish it.
This may sound like a cop-out but you'll find that vendors are very helpful indeed. Laptops aren't easy to repair by yourself .. so .. let the vendor sort it out. Consumer law is on your side.
A few years back I bought a brand new laptop in a computer superstore. When I got it home it didn't work. The next day I went back to the superstore and there in the queue at the customer service desk was a woman who had bought an identical model the previous day .. and it didn't work. All sorted out within minutes.
Feb 10, 2015 | Computers & Internet
Cranks one revolution but wont start.
You should be able to jumper the relay terminals and bypass it to find out.
Feb 10, 2014 | 2004 Pontiac Grand Am GT
My daughter's friend bought a Ford Explorer 1997 with approx. 150k on it. After only a few months, it quit working? He replaced the battery, alternator, starter and the whole ignition switch on the...
Get an auto elec. to check the main Heavy duty fuse box for any burned wires or bad connections. Possibly an alarm system that needs to be bypassed to allow starter circuit to activate.Itend to feel there is a bad connection possibly in the power side.Auto elec could be a viable help.
Jun 03, 2010 | Dishwashers
I hit a deer the other day. I replaced the
try turning on the a/c, if the fan comes on your good to go
Jun 30, 2009 | 2000 Dodge Caravan
My Canon Powershot SD800 IS, has had its lens stuck as if it were zooming out.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Canon SD 870IS - lens error
May 09, 2009 | Canon PowerShot SD870 IS Digital Camera
No Power
Hi:
Some problems cannot be fixed, and I am afraid that if you cannot get the camera to go on with the on/off switch, then there is nothing I can even guess to do. That is because it could be a thousand things. Stating with the on/off switch, the battery connections, the battery interior connections, corrosion, water damage, acid damage from corrosion, burned out parts, broken chips from possible overload, damaged LCD, damaged and broken lens system, a shorted part or motor, and so on. These are only some of the problems I have discovered with the digital cameras I have tried to repair in the last few years.
One thing, if you are not afraid to damage the camera even more, should it not work, is to fold a towel and lay it on a table, then hold the camera (turned off) so that it will come down on it's corner. Don't be too hard, but do use a firm hit down. You may try a few other angles. What this may do, no promises, is that it may jog something inside to allow the camera to start.
If this does not work, then the camera needs repair, and may not be worth repairing. Repairing can cost $150.00 or more depending on what is needed.
Oct 01, 2008 | Fuji FinePix A600 Digital Camera
Fails to start
the problem is your fan may not have got proper power supply....the wire connecting the fan and power chord should be perfect....if there is a loose connection your fan may not get proper power supply and then it will not run.....this is the main probem.....just check the wire connection between the fan and power chord has been properly connected and there are no loose connections....i am a software engineer....and have experience in it....try this ...it will 100% solve your problem.......
Sep 19, 2008 | ASUS P4P800 SE (890552603657) Motherboard
BELKING SWITCH2
I think you must also connect the USB connectors.
Jan 24, 2008 | Belkin F1DK102U 2-port KVM Switch
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
