Question about Amana ALW480DA Top Load Washer
The washer holds water till it gos into the wash cycle then the water drains out the bottom of the washer
  • 95 Answers
This is from the pump
Posted on Nov 18, 2009
We have a kenmore he2 plus. I put in a load Of laundry and when I came back to put laundry in dryer, washer has no power and the door is locked. How can I get the door open and fix the washer
Maybe the filter is clogged and not draining the water. Have you tried cleaning the filter?
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
How to video
Sep 09, 2011 | Kenmore Washing Machines
Control locked, how do I unlock it. I can't start the washing cycle.
OR
OR
OR
Unplug washer
OR press options and select for 10 secs till LOC is no longer displayed
Apr 03, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
My washer keeps draining water during the fill cycle. It pumps the water out as fast as the water is going into the tub. This only happens on the normal cycle-other cycles work OK.
it could be the programer at fault or,,,there is a small pipe from the bottom of the tub that gos to a censor at the top of the washer its the over fill censor pull off the pipe from the censor at the top and blow down it if there is any yuck in it this should clear it out and it may then work ok
Oct 17, 2010 | Whirlpool Washing Machines
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Water does not drain, clicking noise heard no spin cycle
REMOVE DEBRIS FROM PUMP LOCATED INSIDE WASHER ,, REMOVE 2 SCREWS HOLDING BOTTOM PANEL,, PUMP IS PLASTIC TURN COUNTER CLOCK WISE AND REMOVE DEBRIS,, BE CAREFULL HAVE ALOT OF TOWLES STILL HOLD 3 GALLONS OF WATER
Nov 22, 2008 | Kenmore 43142 Front Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Amana ALW480DA Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
