Question about Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range
Stoves 900DFa oven cuts out
I have a Stoves 900DFa dual-fuel cooker. When using the oven, it comes on, gets up to temperature, works as normal for 10-20 minutes (with red "heating" light coming on/off as expected) and then completely cuts out. Any thoughts as to what the problem could be?
    Scholar:
  • 62 Answers
Hi.
The most probable cause is failure in your panel cooling fan 9not the one inside your oven)
If the appliance switches on again after 15 - 20 minutes then the fault is most likely here.
Unfortunately as you have gas the you will need a Gas Safe Certified engineer to repair
Regards
aardvark repairs
Posted on Nov 18, 2009
Testimonial: "Very speedy answer! thank you."
    New Friend:
  • 4 Answers
Yes it the upper cooling panel fan - if no air blowing out of gap at top of door. This causes the overheat switch to operate and shut off the power until its cooled down. It could be the fan itself, or a pcb that controls (back panel middle left) or there is a resistor which can burn out on the fan power supply. Take off back panel and you can see it all in front of you. Its not a gas safe issue -only a competent electrical person you need - not difficult. Parts from espares.
Posted on Mar 26, 2013
Overheating
The top cooling fan is not working which cools the electrics above the oven and the control panel at the front. It could be the fan is faulty , the pcb which controls it is faulty - inside back panel on right. There is also a resistor on the power to the fan which burns out. All easy do it yourself fixes if you are electrical competent.
Feb 26, 2013 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How do I remove the door on a Stoves 900DFa oven?
My range is a different brand, but the door comes off real easy. Open it to the first detent, and then pull straight up on it to slide it off the hinges. Be careful though, the hinges are spring loaded and if you bump them they will easily come off the detent and slamm to the closed position. This will not only scare the sh..it out of you, but will also pinch your fingers real good if you're not careful.
Good luck,
Gary B.
Feb 07, 2011 | Stoves 900DFa Dual Fuel (Electric and Gas)...
STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
Feb 14, 2010 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How do you open the top of a 900DFa?
take off side panels and i think you will find that is where the securing screws are
Jul 04, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Oven heats up then cuts out, no light etc then comes back tolife after 5/10 mins.
Sounds like it could be the thermal cut out switch - I am having a similar problem. The switch is about £10 delivered from the Stoves spares dept. I can't work out how to open the top to change the switch though! Have you managed to solve the problem and can you add anything re opening the top?!
Mar 26, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa dual fuel cooker
check to see if one of the oven elements are burned into if you have an oven cord on it turn the breaker off and check the cord where it connects to the oven
Mar 15, 2008 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves dual fuel cooker
if your qulified enough you need to bypass the timer electrically so as to put power direct to the oven
Nov 10, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Oven cuts out after about 15 minutes
most common fault is the cooling fan is failing to come on, whreas the fan will be okay ( check windings with ohmn meter ) it will normally have a ceramic 10k resitor in series with the live which goes open circiut
Sep 25, 2007 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Stoves 900DFa Dual Fuel (Electric and Gas) Kitchen Range Logo
800 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
