Question about Hitachi Televison & Video
Pip box will not turn off moves all around screen with button but wont turn off lost remote
    President:
  • Hitachi Master
  • 1,779 Answers
Turn the set off and then unplug it for about 30 minutes. If that doesn't work then you will have to locate the original remote.
Remotes.com
Posted on Nov 18, 2009
Turn on pip wiithout remote
If your TV has a Menu button on its front panel, enter its Menu widow, surf through, come to wards picture control window, and make PIP function OFF. If it has no such button, you must have its remote control to turn it OFF.
Jun 07, 2012 | Televison & Video
I HAVE A BLACK SUZRE BOX SHOWING AT THE BOTTOM OF MY SCREEN. SOMEONE TOLD ME THAT IT WAS THE PICTURE IN PICTURE. HOW CAN I GET THIS BLACK SQUARE OFF OF MY SCREEN.
That's a text box not pip. Press the cc button repeatedly on your remote control or go into your menu and find the closed captioning setting. There may not be a menu item for closed captioning. It might be a button on the remote only. You should be able to scroll through the closed captioning options when pressing the cc button to choose off. You are more likely in the text1 or text2 mode right now. If I am wrong and it is pip there should be a pip button that will enable you to turn this feature off (or a menu option). If you need the remote that originally came with this television try http://www.replacementremotes.com/
Jul 22, 2011 | Televison & Video
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
I have a pip on my screen. Can't remove it
somw sets you need to set up in the set-up menu what signal source is shown in the pip box. to turn it off push the pip button on the remote once
Apr 26, 2010 | Sony KP-53XBR200 53" Rear Projection...
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
PIP
The Picture in Picture (PIP) on VIZIO televisions works on multiple input sources. This means you have to have signal or a device connected to more than one input on the television and have both inputs selected to display the information going to them. Here is an example. Lets say you have an HD cable box connected to your television and you would like to have more than one channel displayed on the screen in order to keep an eye on both football games at the same time. With one device connected thats not going to work out the way our TV functions. What you want to do is get a coaxial splitter and two extra coaxial cables, these can be found anywhere home theater equipment is sold. Then follow these steps.
1. Turn off both your cable box and television.
2. Take the coaxial cable that comes OUT from the wall and connects to the IN of your cable box and disconnect it.
3. Connect that cable to the IN on your coaxial splitter.
4. Connect your two extra coaxial cables to the OUTs on your coaxial splitter. We will call them cable 1 and Cable 2, just because.
5. Connect cable 1 directly to the DTV/TV input on your television.
6. Connect Cable 2 directly to the IN on your cable box, this will be the same connection you removed it from in step #2. Your HD cable box should still be connected to your television with either an HDMI cable or Component cables (Identified by thier Green, Red, Blue colors for video and Red and White cables for audio.)
7. Power on both the cable box and your television. Using the INPUT button on your VIZIO remote select the input connection where your cable box is located your cable box picture should come up on the Main screen.
8. Press the PIP button on your VIZIO remote to bring up the small box in the corner. Press the PIP input button until you select the TV input and you should be ready to go. You may need to perform a channel scan with your TV tuner to locate all available channels before you do this step. In order to understand better how to perform a channel scan please check under the F.A.Q.s in the discussion area of your particular model television.
In order to change channels in the small screen use the PIP CH - and +
buttons located near the bottom of the remote. You can swap picture in
the Main and Sub screens using the swap button and swap which screen
will sound off its audio by using the AUDIO button. You might notice an
X next to some of the selections in the INPUT and PIP INPUT screens
when you have PIP activated. That means that input selection is
unavailable and can not be used. For example if you have the input TV
selected on your main screen. If you press the PIP INPUT button and
bring up that input menu you will see X's next to the TV and AV
selections. The X's mean that when you have TV on the main screen you
wont be able to use TV or AV on the small screen. Instead you would need to use any of the input selections that do not have an X attached to them. PIP like this is not possible using any dish or satellite broadcasting companies as all of their signals must go through their boxes to be decoded. The televisions internal tuner can not handle those signals and turn them into anything watchable. If you are using one of these companies contact them to see if they offer a set top box that does PIP on its own and doesn't need the televisions help to accomplish it.
Oct 11, 2008 | Vizio L37 Television
Picture in Picture
I have the same TV. My remote control has a PIP OFF. If you don't then you have the wrong remote control.
Aug 06, 2008 | Sony KP-53V45 53" Rear Projection...
Turning OFF picture in picture!
I have an old Sony Trinitron; had the same problem... somehow turned on the pip while moving the television off its stand. I have neither the remote nor the manual.
Does your tv have a 'demo' button on the front? Mine does; when I pressed it, the pip disappeared!
Jan 06, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
Televison & Video Logo
130 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
