Can i upgrade my ram to ddr3 if so what would you recomend .cheers
  • mickgreenwoo Nov 18, 2009
    my motherboard is a gigabite ga-815xt-fs. the pc is a siemens fugitsu scalio 600 2.6 p4. sorry about the mistake. cheers
  • joecoolvette
    joecoolvette May 11, 2010
    Checking my crystal ball. Nope, bad reception today! You're going to have to tell me WHAT motherboard, or at least the computer manufacturer name, Model Name, and Model Number. Some mobo's have the option of using DDR2 -OR- DDR3.
  • 5,660 Answers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Posted on Nov 19, 2009
Testimonial: "thank you very much. you have been very helpfull.i am trying to get the best out of a old steam powerd machine until i can aford to build my own"
My rig i7-980x Extreme, EVGA X58 FTW3, currently 24GB ram ddr3 pc3-10700h 4gbX6, Win7 Ult 64b. only 16gb usable. 980x says ddr3 1066mhz ram MOBO triple chan ddr3-1600+, supports up to 24GB of DDR3
try swapping the chips around. may not be seated correctly or maybe dud chips. Try putting in 2, do they register 8GB. try the next 2, then the next 2. maybe you find 2 not working.
Oct 19, 2017 | Evga Computers & Internet
Is it possible to increase the SDRAM memory from 4 to 8 GB ?
it is if your motherboard can handle it. run the system scanner and it will tell you how many slots you have and if they can be upgraded or if you are maxed out. by no means do you have to buy their recomended memory, but it is a useful guide.
Crucial com DDR4 DDR3 DDR2 and DDR RAM memory upgrades
Feb 25, 2015 | Computers & Internet
What to do if i have a motherboard which doer not support ddr3 ram
You can either look for the correct ddr memory for your system or upgrade your current board to a ddr3 compatible one
Mar 20, 2014 | HP Computers & Internet
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
Ram Upgrade
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
you will need to select your motherboard
hope it helps you
Feb 10, 2012 | Computers & Internet
What is maximum ram i can install in Asus U50F laptop and what kind
Asus U50F has 2 memory slots (204-pin SODIMM).
Each memory slot can hold DDR3 PC3-8500, DDR3 PC3-10600 with a maximum of 4GB per slot
for a total of 8 GB ram.
Mar 05, 2011 | ASUS U50F Notebook
Will my Gigabyte GA-8I915P Duo Pro Motherboard take ddr3 and ddr2memory upgrades
This motherboard can take a DDR2 RAM , this are the supported RAM for it Dual Channel DDRII 533 / 400 or Dual Channel DDR 400 / 333.
Feb 11, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
Upgrade RAM
DDR 1 - 1 GB costs around Rs 1500 DDR 2 - 1 Gb costs around Rs 1200 DDR 2 - 2 Gb costs around Rs 2200
I just upgraded my system to 2 Gb ddr2.
You can order it on ebay.
Mar 29, 2010 | Lenovo 3000 Y410 Laptop
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
Electro Med Services...
