Question about Samsung J700 Cellular Phone
When i switch bluetooth on it says 'activating bluetooth' then the phone freezes
3 Suggested Answers
  • 33 Answers
SOURCE: My Samsung D900 freezes when I activate bluetooth
Bluetooth module needs to be replaced. Bluetooth module gets to be faulty very easy, because it is on the side of the phone, so just a small drop can damage it. There is a glue around it, it this is cracked your phone is already out of warranty due to customer abuse. Other thing what can appear with your phone is short battery life. That was me, b4 registration :)
Posted on Sep 22, 2007
pathtricko
  • 24 Answers
SOURCE: Bluetooth freeze
I flashed mine ,now its ok
Posted on Dec 01, 2008
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
Can't turn bluetooth on. If I restart the phone and then turn on bluetooth, I get a message "Switching On Bluetooth" but it doesn't turn on. After that, nothing happens when I select "on", not even the...
Set up a Bluetooth connection
Select Menu > Settings > Connectivity > Bluetooth and take the following steps:
1. Select My phone's name and enter a name for your phone.
2. To activate Bluetooth connectivity select Bluetooth > On. indicates that
Bluetooth is active.
thanks
May 16, 2010 | Nokia 6301 Cellular Phone
Bluetooth problem unable to find other bluetooth devices and will not switch on
Perhaps a question of interoperability. Just check if you have infrared that this one should not be activated. You can also retreive the battery of the phone during a minute and put it on again and activate the Bluetooth.
But no one know if your bluetooth is still working, but most of the kit into the activation, the blue light is shining.
Check also the set up of bluetooth application to the phone and change it if necessarly.
Mar 17, 2010 | Nokia 5800 XpressMusic Smartphone
Bluetooth fails to deactivate
the chip of bluetooth works with the smal program on the cellphone.  there are two option. software or chip is broke down. should go to service.
May 29, 2009 | Samsung SGH-D900 Cellular Phone
Agreed bluetooth passcode required to pair phone and hands free k
1. Make sure that the mobile phone is switched on and the battery is
charged.
2. Switch on the Advanced Car Kit. For further information, see
“Switching the Advanced Car Kit on/off,” p 20.
3. Open the Bluetooth menu in the mobile phone and activate the
Bluetooth function.
4. Make the required settings on the mobile phone to activate a search
for Bluetooth devices within range. For further information on the
settings required on your mobile phone, see the relevant user guide.
5. Select Advanced Car Kit from the list of Bluetooth devices found.
6. When prompted, key in the Bluetooth passcode 0000.
Jan 03, 2009 | Nokia 3110 Cellular Phone
Bluetooth freeze
Nov 25, 2008 | Samsung SGH-D500 Cellular Phone
Bluetooth
do a hard reset *2767*3855#
May 20, 2008 | Samsung SGH-D900 Cellular Phone
Bluetooth dont work
well you need to get the phone firmware reflash take the phone to a mobile service center and have them reflash the firmware for a small fee.
Dec 30, 2007 | Samsung SGH-D900 Cellular Phone
Sep 20, 2007 | Samsung SGH-D900 Cellular Phone
Samsung J700 Cellular Phone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
