Question about Insignia IS-LCDTV32 32 in. Television
I have an Insignia 32'' lcd tv. I shut it off by
I have an Insignia 32'' lcd tv. I shut it off by pressing the power button and got what felt like a static shock. Ever since the TV won't turn on.
  • 834 Answers
When you got off the couch to turn of your set you gave it a static charge which corrupted the CPU try unpluging unit for 30 seconds see it that fixes your problem if not you will need a main board
Posted on Nov 18, 2009
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
I have an insignia 32 LCD TV, it wont power up but the LED blinks when you hit the power button or the remote.
It is a bad power supply and that is common on that set, if you remove the back of the set and check the power supply board, you will find a couple of electrolytic caps that need change, or just replace the power supply.
Nov 14, 2010 | Insignia IS-LCDTV32 32 in. Television
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Insignia 32" begins to power up but shuts down right away
Unfortunately, your TV requires repairs. In-home service can be obtained by calling 1-888-237-8289 in the U.S. or 1-866-237-8289 in Canada.
Jan 06, 2010 | Insignia 26 in. LCD Flat-Panel HDTV
Insignia 32 HELLP
You can find parts for your TV here. If the power supply is an internal component, it is strongly recommended that it be installed by a TV repair professional.
Sep 30, 2009 | Insignia IS-LCDTV32 32 in. Television
TV picture doesn't fit in screen no matter what the setting
Ok, so I think I have your solution :)
You're actually my first when it comes to this site, so hopefully this fixes your problem!
Step 1 - Turn off the cable box, but leave the TV on
Step 2 - On the front of the 8300HD, press the "guide" button and the "info" button at the same time
Step 3 - Choose "HD" for High Definition, or "SD" for standard definition. (Sounds like you're HD?)
Step 4 - Choose the aspect ratio 16:9
Step 5 - Choose "progressive scan" if it asks you.
Now press the "power" button on the box, does that fix it?
Apr 03, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
32'' Insignia LCD is flashin colrs. wh,blk,rd,grn,blu. audio wrks
Very well could be the circuit board. What you describe is VERY common in newer tv's. The company says this supposedly this will be fixed in the new firmware they claim will be sent out soon. The only way you shouldn't experience it, is if I hook nothing to the HDMI input.
My solution is: You have entered a diagnostic color test. With the TV powered on, hold the 'Menu' & 'Enter' together, then press the power button.
Jan 14, 2009 | Insignia IS-LCDTV32 32 in. Television
TV won't turn on
Same thing happened to me......The tv repairman replaced a transformer, and it was doing ok.
Nov 27, 2008 | Insignia IS-LCDTV32 32 in. Television
INSIGNIA PORTABLE DVD
Use the A/V outs to the composite cable and connect to your Westinghouse A/V jacks.
On the Insignia player, press the Source button until you see A/V OUT on the insignia players screen.
Set your Westinghouse to the A/V input port you have connected the Insignia player to and VIOLA...you should have picture and sound.
Nov 11, 2007 | Insignia IS-PDVD10 Portable DVD Player
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
403 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
