Question about HP Photosmart 8250 InkJet Printer
Ink cartbridge expired. Solution is set clock
Ink cartbridge expired. Solution is set clock back one year. How can I do this? I'm jam with the error message.
SOURCE: ink cartridge
I did try the battery removal (lower left-Inside on motherboard extention) and it didn't work. Then did a soft reset and power down with the batery removed. powered back up (Still no battery) Powered down, reinstalled the battery, powered up and was
able to print. No expired message at all!
Posted on Jun 05, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
leroyal
  • 2120 Answers
SOURCE: supply expired
You can't. Cartridges have a date bomb built in, they may be expired.
Posted on Jan 20, 2009
CompuFirm
  • 89 Answers
SOURCE: Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
Then go to page 62 and allign the print head automaticly following the instructions it gives.
This will re-callibrate the ink level on the printer and should read correctly for you.
Thanks
CompuFirm
Posted on May 27, 2009
professor_sc
  • 180 Answers
SOURCE: HP psc 1310 - gave paper jam and print cartridge
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Posted on Oct 28, 2009
Override ink expiration HP c7200
Change the printers clock to an older time - you can do this by typing the IP address of the printer into your browser and then clicking on the Settings Tab and then Time services. Works for HP c7200. You can get the IP address of the printer (if you don't know it) from the menu on the printer.
Jun 19, 2012 | HP Office Equipment & Supplies
How to get a valid yahoo certificate update because mine got expired
Hi there, the simplest way to resolve certification error is by fixing your computer's date. If the clock's date was set wrong, then it sends expired security certificates. I hope that helps.
Jul 07, 2011 | Computers & Internet
I replaced the color cartridge with a new one. The new cartridge was the wrong size. I placed the old colour cartridge back in the printer and now the printer will not work. The ink drop for the colour...
Hp is known for being a pain with ink.
We once had a business jet that would not print because our ink had expired lol...
The printer wont work because it know's that the old cart has no ink. And since it needs all three colors along with black to print it will not do it, Usually you can set the printer to print only black under properties or print settings.
Other then that you will need another cartridge. You can also try one more thing. If you need to print in a Pinch, down on the right hand part of your screen, Is the clock. Double click it and change the date back a year from today and see if that helps you print
Oct 06, 2010 | HP Deskjet 6980 InkJet Photo Printer
Refill lexmark 2550 cartbridge black 28
Printer is fuelled simply syringe of same type of the ink Inwardly cartridge is found porous material, which holds filling an ink.
Dec 08, 2008 | Office Equipment & Supplies
My rsa securid shows no code to input for access the only number on the screen is a small no 3 in the right hand botton corner
This means the device is about the expire. Your SecurID has a expiration date stamped on the back.
Oct 10, 2008 | Computers & Internet
HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Sep 10, 2008 | HP Business Inkjet 1100dtn Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
The black cartbridge is not printing and won't align
Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
May 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
Seeker5211
Seeker5211
