Question about Intel Refurbished MICROPROCESSOR SYSTEM CONSOLE (USCOPE820) Network Adapter
Hi just a small question for my coursework why is microprocessor is used in the server?
    Guru:
  • 1,738 Answers
It helps the speed. The faster the speed is the faster the internet. You have a 800 MHZ and 3 Meg you might only run 2 Megs speed. If you had a 1.6 gig you almost get 3 megs of speed, depanding on your location.
Posted on Nov 25, 2009
What should be followed before write an essay?
I'll suggest you to practice a lot of writing everyday.And you should read many of article and reading essay book regularly.And enhance your informational knowledge by reading of current topics of different things.You should attend with some essay competition to make your writing skill good.Try this site for more help.
http://www.poweredessays.com/blog/critical-essay
Jan 19, 2014 | Custom Essay Computers & Internet
Dell Poweredge SC430 Shows error Code 3.
Wow!
Haven't seen anybody use the term Microprocessor, for a long time.
How about CPU instead? Shorter, easier to type, carries a certain 'savior faire' to it; and will help teach people not to use it to mean PC. Personal Computer.
(Central Processing Unit. Microprocessor is another term used, or simply Processor for short )
I'm going to assume you are following Anti-Static Procedures.
If not the CPU's you have touched, are now key chain fobs.
(Drill a hole through them for the chain, lol!)
Have to go through the basics. It isn't an insult to your intelligence, I just need to go through a diagnostic flowchart in my mind.
CPU installed the correct way? Aligned correctly?
With the LGA 775 processor socket, the CPU can be turned, and installed wrong,
http://en.wikipedia.org/wiki/Socket_T
http://en.wikipedia.org/wiki/File:CPU_Socket_775_T.jpg
That little alignment 't1t' can get crushed.
What CPU did you install?
Do you know if it is supported?
The motherboard chipset is an Intel E7230,
http://www.intel.com/content/www/us/en/chipsets/server-chipsets/server-chipset-e7230.html
Supports;
A) Dual-Core CPU's
B)Front Side Bus support of either 800MegaHertz, or 1066MHz
(800MHz / 1066MHz FSB)
C) Hyperthreading Technology (HT)
However, depending on the CPU, you may need to perform a BIOS update.
With the old CPU going out, and now the new CPU doesn't work, I would suggest going back to the start of the diagnosis, and look into the Power Supply.
The Power Supply is the FIRST thing to look at, when diagnosing a desktop computer. Server notwithstanding.
A Power Supply with a weak voltage power rail, will emulate all sorts of software problems, and hardware problems.
Have a multimeter to use to test the 3 main voltage power rails?
(3.3 Volts DC, 5 Volts DC, and 12 Volts DC)
Or;
Have a KNOWN to be good, Compatible power supply, you can borrow for a temporary test unit?
Post back in a Comment.
Regards,
joecoolvette
Apr 14, 2013 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
Hi
To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
Windows Server 2003 R2 Standard Edition
Windows Server 2003, Standard Edition SP1
Windows Server 2003, Standard Edition SP2
Windows Storage Server 2003
Windows Small Business Server 2003
If you are using : Windows Server 2003, Web Edition
It will support only 2 GB of RAM
For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
(msdn.microsoft.com/en-gb/library/aa366778.aspx)
If you find it useful please do not forget to rate this solution.
Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
Hi My server has 8 memory slots but only 4 seem to be working. How can I make all of them work
It depends on the version of Server OS you have. If you already have 4 GB of memory installed and you're using Small Business Server 2003 or another 32-bit Server OS, then that is all the memory you'll be able to use. In order to use the other slots, you'll need to upgrade to a 64-bit OS. (Full Windows Server 2003 64 bit or later).
Mar 10, 2010 | Computers & Internet
Hello , HP Proliant Server Problem.
Use a different monitor and connect it directly to the server, if problem persist you have a problem with the systemboard or microprocessor.
Jun 29, 2009 | HP ProLiant DL380 G4 36 GB Network Storage...
SQL Server and Internal Website
i would expect that the hostname of your webserver has changed. this means that the custom software you are using needs to have this changed as well otherwise it will continue to look for your old server...
you could also change the server name to be the same as the old server and that should solve the problem as well
please remember to rate this answer if it has been useful
thanks trev
Jun 19, 2009 | Microsoft SQL Server 2008 for Small...
Define microprocessor
microprocessor, integrated circuit containing the arithmetic, logic, and control circuitry required to interpret and execute instructions from a computer program computer program, a series of instructions that a computer can interpret and execute; programs are also called software to distinguish them from hardware, the physical equipment used in data processing .
..... Click the link for more information.
. When combined with other integrated circuits integrated circuit (IC), electronic circuit built on a semiconductor substrate, usually one of single-crystal silicon. The circuit, often called a chip, is packaged in a hermetically sealed case or a nonhermetic plastic capsule, with leads extending from it for
that provide storage for data and programs, often on a single semiconductor semiconductor, solid material whose electrical conductivity at room temperature is between that of a conductor and that of an insulator (see conduction ; insulation ).
base to form a chip, the microprocessor becomes the heart of a small computer computer, device capable of performing a series of arithmetic or logical operations. A computer is distinguished from a calculating machine, such as an electronic calculator , by being able to store a computer program (so that it can repeat its operations and make
, or microcomputer. Microprocessors are classified by the semiconductor technology of their design (TTL, transistor-transistor logic; CMOS, complementary-metal-oxide semiconductor; or ECL, emitter-coupled logic), by the width of the data format (4-bit, 8-bit, 16-bit, 32-bit, or 64-bit) they process; and by their instruction set (CISC, complex-instruction-set computer, or RISC, reduced-instruction-set computer; see RISC processor RISC processor [Reduced Instruction Set Computer], computer arithmetic-logic unit that uses a minimal instruction set, emphasizing the instructions used most often and optimizing them for the fastest possible execution.
). TTL technology is most commonly used, while CMOS is favored for portable computers and other battery-powered devices because of its low power consumption. ECL is used where the need for its greater speed offsets the fact that it consumes the most power. Four-bit devices, while inexpensive, are good only for simple control applications; in general, the wider the data format, the faster and more expensive the device. CISC processors, which have 70 to several hundred instructions, are easier to program than RISC processors, but are slower and more expensive. Developed during the 1970s, the microprocessor became most visible as the central processor of the personal computer personal computer (PC), small but powerful computer primarily used in an office or home without the need to be connected to a larger computer. PCs evolved after the development of the microprocessor made possible the hobby-computer movement of the late 1970s, when
. Microprocessors also play supporting roles within larger computers as smart controllers for graphics displays, storage devices, and high-speed printers. However, the vast majority of microprocessors are used to control everything from consumer appliances to smart weapons. The microprocessor has made possible the inexpensive hand-held electronic calculator calculator or calculating machine, device for performing numerical computations; it may be mechanical, electromechanical, or electronic. The electronic computer is also a calculator but performs other functions as well.
, the digital wristwatch, and the electronic game electronic game, device or computer program that provides entertainment by challenging a person's eye-hand coordination or mental abilities. Made possible by the development of the microprocessor , electronic games are marketed in various formats, such as hand-held
. Microprocessors are used to control consumer electronic devices, such as the programmable microwave oven and videocassette recorder camcorder combines a video camera and VCR in a single handheld machine.
The first commercially successful VCR, which used a Betamax format, was introduced in 1975. A competitive format, VHS (Video Home System), was introduced in the same year and became the dominant system.
; to regulate gasoline consumption and antilock brakes in automobiles; to monitor alarm systems; and to operate automatic tracking and targeting systems in aircraft, tanks, and missiles and to control radar arrays that track and identify aircraft, among other defense
Mar 30, 2009 | Computers & Internet
Network User Accounts
Hi Ben,
You have 6 people in your family. Are Bob and Fred the only person in your family having coursework? If they are the only ones then all you have to do is create a shared folder for both Bob and Fred. You can password the folder if you like so that only Ben and Fred will be able to access their coursework folders. You can place the shared folders either on the upstairs computer or the downstairs one, it does not really matter. So even when Fred is using the computer upstairs, Bob can still access his own coursework folder by using the computer downstairs. Hope it works for you.
Dec 25, 2008 | Microsoft Windows XP Home Edition
Cannot turn it on using either the remote or set top switch. There is a click and red light blinks but no sound or picture. For some time if I hit the on button 5-6 times it would work but now it does not...
the initial symptom is usually caused by microprocessor as it is not initializing correctly. followed by 4 blink error which is i2c communication failure also specific to microprocessor would recommend replacing small signal board as microprocessor is located on that board
Jul 21, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Adding second CPU
Hi
Did you receive a VRM with the the PRC upgrade kit? And have you installed it?
The following items are/should be included in a microprocessor upgrade kit:
• A microprocessor (PRC)
• A heat sink
• Heat-sink retention clip(s)
• A voltage regulator module (VRM),
Your upgrade kit may also include a cooling fan.
If you are adding a secondary microprocessor, examine the VRM to ensure that it is the correct VRM for your system. Install the VRM in the appropriate secondary VRM connector, ensuring that the latches at each end of the connector engage. If you received two VRMs with the upgrade kit, replace the primary VRM already installed in the system with one of the VRMs from the upgrade kit.
Note: The system does not support mismatched VRMs.
Check PE1600sc Microprocessor Upgrade Installation Guide - http://support.dell.com/support/edocs/systems/pe1600sc/multlang/proc/9D904A05.pdf
Let me know how you get on
Mike
May 13, 2008 | Dell PowerEdge 1600SC Server
Computers & Internet Logo
295 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
