Question about Dryers
Why does water leak from the condenser compartment of our aquarius ctd00 ? We have flushed the condenser to clear fluff as recommended. Is there a compartment that needs cleaning out, that I am unawre of. This problem has occured once before, when we first bought the tumble dryer & was fixed by an engineer under warranty, but it appears to have reappeared. My wife thinks the engineer cleaned a compartment, but doesn't know where or how?
    Scholar:
  • 62 Answers
Hi.
I have had a few calls to these appliances. The fault is most likely to be in the water pump area. This pumps the water from the back of the condenser unit to your condenser drawer at the top of the appliance.
if you turn your appliance around and look at the bottom right you will find a grey box. inside here is the water pump assembly. these have been prone to fail so the water leaks out.
There is a conversion kit that very easy to fit.
If you need the part number for this or would like me to obtain one for you please email me on aardvark.repairs@btinternet.com or call me directly on 01733 307019
regards
Aardvark repairs
Posted on Nov 18, 2009
Hotpoint aquarius condenser dryer ctd00 - empty water light will not extinguish after water has been emptied resulting in no heat
The float switch within the plastic unit at base of machine has failed,shorted out Carefully prise the unit open Disconnect and identify the three tags Replace switch and attached lever Examine the insulation on the rear tags as they are very close Reinstate Red light will now extinguish pump will run when float operates hearers will come on
Oct 15, 2009 | Hotpoint Dryers
I have a Hotpint Aquarius CTD00 Condenser Tumble Dryer, it has stopped drying the clothes. It occassionally works on the high setting (but makes my clothes smell a bit burned out and shrinking) but it...
it could be blocked up with lint, take out the condenser (silver fin bit) and clean run under a tap if necessary, this is the most important bit of the condenser if this is dirty it reduces the efficiency of the dryer. clean all filters with a vacuum cleaner even remove them and clean where they sit in the machine with the vacuum cleaner.
for the reservoir remove a check the inlet is clean and clear. look inside the machine where this is located and again clean and clear this area, then using something long and thin press open the valve that the reservoir mates with (this can often stick with lint and water residue) be-careful though when opened the valve will **** out water so have a few towels to catch it all. and finally raise the front feet a little this will help the water fall to the reservoir.
if this does not work the internal tank may have fluff and this would be a big job to get to this and clean it you have to strip the drum out which can be a pain.
Jul 22, 2009 | Hotpoint Dryers
Hotpont aquarius condenser dryer wont heat
There are a number of reasons for dryer not to heat, first and foremost is failure of the stats and or element. You will find these located behind a removable cover at rear of dryer.
If you know how to use a meter, then test these for continuity.
If o/k then it gets more involved as there are several other possibilities and you need to know what you are doing.
The only other thing to check is that all the filters and air inlet and outlet vents are clean, particularly the one at the front left. pull out and wash under running water to flush all fluff out.
Plz rate my solution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer not heating/drying
To check the element and stats, you need to remove the rear panel of the dryer, there you will see the stats and the element, you need to check for contin uity with a meter set on the ohms range, do it with the stats disconnected, or you will get a false reading.. if one of the stats has gone, then you must replace both of them.
Check thst all filters are clean ,air intake and outlet clear, and wash the lower fluff filter out under a running water supply.
If still no joy ,then could be a control unit prob..
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD640 Front Load...
Thermostat keeps blowing on Hotpoint Aquarius dryer
Remove the filter completely from the bottom left of m/c
Wash out thoroughly under running water.
Reach in with your hand and clear any fluff and gunge you can find there.
At the rear of the filter housing there is a small drainage hole that blocks up.get a plastic bag tie or similar and poke it clear. Also there is a float chamber and some times the float sticks, this being the case , then it involves a complete strip down to clear prob.
Hope this helps
Plz rate solution
.Thanks.
Dec 29, 2008 | Hotpoint TDC32 Electric Dryer
Hotpoint aquarius CTD00 dryer
how many fuses are there in a hotpoint tumble dryer CTD00 aquarius I know one is in the plug is there another one if so where is it?
Aug 18, 2008 | Dryers
Hotpoint aquarius CTD00 dryer won't heat
I have just had a similar problem and fixed it today.
The "Empty Water" light was staying on and no heat was given out to dry the load.
I found it to be the float switch in the condenser unit at the back left. It had stuck with fluff and debris. I cleaned out the condenser reservoir and the polystrene float and now all is well.
To get to this unit you must first,
Take of the top and the left hand side panel.
Locate the 2 locking tabs that hold the top half of the condenser onto the back panel and release this part.
Remove this by releasing 2 further tabs that hold it to it's bottom half,
and you will see the float switch assembly on the left hand side.
Clean out the condenser reservoir of any water and aslo clean the polystyrene float, it needs to be free to slide up and down between the plastic guides.
Hope this helps.
JohnM
Jun 28, 2008 | Hotpoint NWXR473EV Dryer
Dryers Logo
171 people viewed this question
Top Dryers Experts
