Question about DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator
Delonghi TRN1015T wiring diagram
Delonghi TRN1015T
My timer makes a ticking noise,  I would like to bypass it since I don't ever use it. Could someone please email a wiring diagram or tell me which pins to jumper on the timer in order to bypass it.
Thanks in advance for your help
shirsh@bellsouth.net
  • katlou Jan 13, 2008
    Yes, but different model (can't find the model number). It is called "The Incredible Heat Machine". Any suggestions?
Just wondered how you learned to turn off the timer.
Posted on Jan 13, 2008
My delonghi oven is making a ticking noise and with all the switches turned off it's is still heating and rather hot. Won't turn off and cool down
Sounds like an improperly grounded element in the circuit... If an element or wire makes contact with the metal frame and welds itself in place, the electrical current can BYPASS the control and heat uncontrolled- throw the circuit breaker to interrupt the power.
A thorough inspection must be made of the elements and wiring.
Help Me Find My Model Number
Dec 12, 2016 | DeLonghi Ovens
What is the intermatic e 1020 used for just moved into a house andits in the bathroom and makes a lot of noise.
The E1020 timer is reliable heavy-duty 24-hour on-off analog timer with replaceable trippers and manual override, rated 12 amps.
This timer replaces ordinary single-pole on-off switch.
Timer has extra white wire that connects to white neutral wires inside box to run timer mechanism, while mechanical single-pole switch does not need this wire.
I don't know what it is doing... maybe running the vent fan periodically, or turning on attic vent fan?
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#E1020
http://waterheatertimer.org/How-to-set-timers.html
For same timer, with less noise, install E1100-1200 aka the KM series in-wall analog timer. Or install digital in-wall timer, or replace timer with on-off switch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 11, 2012 | Intermatic Timer E1020, Single pole/single...
Wont spin or drain makes ticking noise
Maybe the timer is not running.
Can you turn the timer ahead manually a step at a time? Then if you don't hear the motor running the timer may not be working or sending signals to motor to start. . But If the motor starts a spin cycle then the timer is just not running itself probably dut to not getting power.
All this is difficult without the diagrams. There are so many interlocks and safety switches that you wont know about
Jun 26, 2011 | GE WWRE6260D Top Load Washer
How to bypass mtd8
To permanently bypass the timer, you have to move wiring.
I don't have specific wiring diagram or programming manual for mtda8 timer, but am familiar with wiring din-rail mounted digital timers.
1) Wiring is typical across all din-rail timers, with variations of same theme depending on number of channels and purpose.
2) Open following illustration of wiring:
http://waterheatertimer.org/images/DIN-series-wiring-300.jpg
Same-similar illustration shows on side of timer.
3) Notice the mtda8 has 5 screw terminals.
4) Two screws are for incoming power. These terminals are usually labeled 1 and 2. These wires power the timer.
5) Three more screws are for the timing relay. These screws are usually labeled 3 4 and 5.
Typically the #4 center screw is common, and carries power. And when timer is ON, power is live between #4 and #3 terminal. When timer is OFF, power is live between #4 and #5 terminal.
6) Move #3 wire to #4 or #5 screw and then the timer function is bypassed.
Jun 15, 2011 | Hardware & Accessories
Does this timer make any ticking or loud noises??
Every mechanical device makes some noise.
Plug-in timers generally are NOT noisy because the switch and trippers are plastic.
Direct-wire timers that are made of metal are noisy when the switch clicks on-off.
Feb 18, 2011 | Heavy Duty INTERMATIC 6 Outlet Outdoor...
It stopped working
If its like the TRN0812T, I had to reset the small circuit breaker under the control panel/cover, had to remove the 2 torx screws under the leg on the control panel side.
Feb 02, 2011 | DeLonghi TRN1015T Solaris Oil-Filled...
Was working yesterday, now it won't turn on
http://www.fixya.com/support/t8108827-stopped_working
Jan 31, 2011 | DeLonghi TRN1015T Solaris Oil-Filled...
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
Dead Delonghi toaster oven
Your timer switch burned out. The timer is manual and will tick even unplugged. Delonghi switches are available at The Gourmet Depot website or search "small appliance parts" for other places that sell the switches.
Mar 23, 2009 | DeLonghi EO1258 - Stainless Steel Toaster...
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Open Questions:
DeLonghi TRN1015T Solaris Oil-Filled Heater Oil Filled Radiator Logo
1,727 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
