Question about Weaver Marlin Rifle Picatinny Rail Base Scope Mount M8
Bullets get gamed and lever locks up in open position. Son took it apart to clean side door n wrong place. bullets don't load the way it did Bottom slide to load seams to be in wrong place. load door in wrong position . tryed to find diagram for gun no luck. Pissed at son right now. marlin 30 30 336a lever action.
    President:
  • 2,702 Answers
Have a look on the internet there are blow up photos of the marlin rifle there realy very easy to strip, but putting them back right,,,
well your lad did not! *** him!! wip the screw out the side for the under leaver half open the bolt and pull the under leaver down and out the gun, then pull the bolt out the rear end,,you may see what he has *ucked up in there,,,the side loading door is held on be a small screw if you drop the side door into the gun you will need to strip out the loading leaver as well to put it right,,,so dont do that!,,, let the side door screw off just a little and put the door in the right place then nip up the screw,, dont strip it!!! then slide the dolt half way into the rifle and push the loading under leaver back into the bolt,, put the under leaver screw back in and close the bolt with the leaver,,,if its not closing its in wrong again,,,rember you need to engage the leaver in the bolt before you can close the bolt,, if its not picking up the rounds its the lifting arm,,,thats a man size job look on the net for the blow up photos,,,but you may well need some expert help then,,,im not there but if i was i could strip it in my sleep? but go to googel,, and type in "marlin rifles"
Posted on Nov 18, 2009
Testimonial: "Thank you for your time.I tore it down,,found the lifting arm at the end near barrel bent open more then it should,locking the lifting movement,TY Don"
How di get 1999 mercury mountaineer driver side door open lock wont release
You will need to take the inside panel off to see what has come apart, broken or is binding.
Jan 10, 2015 | Mercury Cars & Trucks
Putting door back on but hinge wont release to put back on
Hi Susan, this is AP! Thank you for your post.
I understand you are having trouble putting the door back on your Frigidaire wall oven. Without knowing exactly how you removed the door I cannot say with certainty how to reattach the door. However, when removing the door did you pull up the lock located on both hinge supports and engage it in the hinge lever hooks? You might have had to apply a little downward pressure on the door to pull the locks fully over the hinge lever hooks. Then grab the door by the sides and pull the bottom of the door up and toward you to disengage the hinge supports. If so, then to reattached the door grab the door by the sides; place the hinge supports in the hinge slots. Open the door to the fully opened position. Disengage the lock from the hinge lever hooks on both sides. Make sure the hinge supports are fully engaged before unlocking the hinge levers. Then close the oven door. There are instructions with images to remove and replace the oven door in the owner's manual. I hope this information proves helpful for you.
Mar 14, 2014 | Frigidaire FEB30S6D Electric Single Oven
2011 ford fiesta Rear driver side door lock won't lock
Clean and check the child safety lock lever.
Lever stick to the wrong position or middle will cause this problem.
Jan 11, 2014 | 2011 Ford Fiesta
Oven door won't close
if you look around under the handle or under the top of the stove on the front there should be thin lever. This lever is designed to lock the oven door closed tightly when you are activating the self cleaning oven feature. It is likely that someone accidentally lock the lever while the door to the oven was open. Simply find that locking lever return it to the unlocked position and your door should shut fine.
Dec 26, 2013 | Ovens
We have a Konica C203 printer. The right side door wont open. The release lever won't open door. Is there a way to take the door apart to get to the release lever.
yes the right side of the door on the bottom there is a spring loaded hinge you may be able to push it in to remove the door
Nov 09, 2010 | Konica Minolta Bizhub c203 Copier
Both door locks do not work properly. I can only open the drivers side door from the inside. And the passengers side door will not open at all. This is on a 1999 Ford Explorer Sport.
Do any of the door handles inside or out feel sloppy (when you pull on them does it feel like there is nothing connected to them)?
If so that the levers on the latches are probably rusted up and sticking. Say for example the outside door handle lever that is attached to the door latch is stuck half way in the open position it will not allow the door lock mechanism to lock or unlock. The door will still latch and stay closed because the lever will not be stuck far enough to release the latch mechanism from hold on to the striker.
I have had pretty good luck removing the door latch (the part that actually holds the door closed) and soaking in penetrating lube and working all the levers until they move freely.
As far as the door that doesn't open I suspect it is stuck in the lock position and one of the handle mechanisms is in the partial up position. Again the symptom would be a sloppy door handle. That lever will need to be put back in its normal resting position before the door can be unlocked. This can be done with a slim jim. Once you have the door panel apart on the door that still opens you will be able to see the parts you need to move. You can then use that knowledge to move those parts on the other door that doesn't open.
If you don't have any experience with a lockout kit (i suspect most people do not) that that's the best way I can describe how you can do this yourself.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 29, 2010 | 1999 Ford Explorer
Machine flashes F then dl. What can we do?
There's a fault detected with the door lock and switch assembly. The door lock is not working or the door lock switch is not activated. This indicates that the door lock and switch assembly is malfunctioning and needs to be replaced to address the problem.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Using needle nose pliers, start where the spring and wire are connected and pull the wire out of the groove of the door gasket.
Remove the three screws securing the door lock and switch assembly to the front panel.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Slightly lift the door lock and switch assembly then pull it back off the front panel and out of the cabinet.
Transfer the wiring harnesses to the new door lock and switch assembly one at a time then install it in place behind the front panel. Secure the
door lock and switch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Install the retaining hoop with the spring positioned at the bottom of the door gasket.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My door lock has locked with the door open , how do i get it to unlock ?
There is a manual unlocking tab located at the bottom of the door lock and switch assembly. Disconnect power to the washer before accessing it.
Remove the three screws attaching the toe panel to the cabinet then pull the panel down and off the cabinet. Prop up the bottom front edge of the washer or cushion and lean it against the wall for an easy access of the screws.
Reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side.
Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel.
Pull the door lock/latch assembly out of the washer and disconnect the wiring harness.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel.
Secure the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Jul 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Took the door off my oven to clean it can't get it back on
I put something behind the hinges, usually screwdriver handles, to hold them open long enough to slide the door onto the hinges. If you have the style that has the hinge on the door, you usually have to stick a nail into a hole in the hinge (in the open position), that is designed to hold it in the open position. Install the door, and remove the nail. Another design has a lever that has to be rotated into the locked position on the hinge. You have to be pretty strong for some of these hinges to pull the hinge out enough to lock the lever in place. If this is your style make sure you lock the lever before you remove the door next time. Good Luck, Appliance Specialists
Jan 25, 2010 | GE Ovens
Maytag double oven-top cleans itself-bottom reads unavaiable?
Either BOTH cannot clean at the same time b/c they heat to 700deg and use alot of power, OR the 'Door secure' signal from the bottom oven is not getting to the controller. I suspect if that is the case, the switch is on the inside of the door, activated by the LOCK lever moving into locked position. It may be a beny switchlever, mis-adjusted LOCK lever or solenoid or disconnected wire.
If you leave the TOP open and force a clean, does the bottom lock and do nothing? (My other theory)
Apr 08, 2009 | Maytag CWE5800A Electric Double Oven
Weaver Marlin Rifle  Picatinny Rail Base Scope Mount M8 Logo
283 people viewed this question
Top Weaver Optics Experts
colinat108
james laughton
james laughton
Are you a Weaver Optic Expert? Answer questions, earn points and help others
