Question about Logitech Cordless Mouse
Wireless mouse will not connect to pc. only getting F light on receiver
  • 128 Answers
Check your batteries and then reinstall drivers
Posted on Nov 18, 2009
Will not connect..its not in sync with my pc
Hello
Turn the switch to the "On" position, located underneath your mouse if your mouse has a switch.
Restart your computer to have a fresh starting point for troubleshooting. Sometimes, just restarting your computer can resolve issues you have with your HP wireless mouse.
Move your HP mouse about 39 inches away from your receiver.
Unplug your USB receiver, if you have one, and wait about 10 seconds.
Replug the USB receiver into another USB port, closer to your mouse if possible, then resynchronize your mouse and receiver.
Press and hold the connect button on your receiver, while plugged in, until you see the LED light flash.
Hold and press the connect button underneath your mouse until the LED light on the receiver stops flashing.
Check to make certain the button under your mouse does not get stuck in the depressed position and releases. Also, make certain you complete this resynchronizing process in 60 seconds, or else you must start over. Your mouse will now have a new identification number from resyncing.
Unplug the USB receiver, wait 10 seconds, then replug the receiver firmly into the USB slot, pushing it in entirely. You will notice the receiver's activity light turn on, then off in the next five seconds.
Press the connect button underneath your mouse until you see the activity light turn on again on the USB receiver.
Check to make certain the mouse connect button does not remain depressed when you release it.
Nov 14, 2010 | HP Wireless Optical Mouse
The microsoft wireless mouse stopped working after a power failure. I get a message that says the USB device is not there. But I cannot navigate my computer w/o the mouse
The Microsoft wireless mouse comes with a wireless receiver, right? Before you do anything, the first thing that you can try is to replace the batteries with fresh ones.
If same problem occur, try to connect the wireless receiver into different USB ports of the computer. Then check if your wireless receiver and mouse has a connect button. If it does have connect buttons, briefly press the connect button on the receiver, then hold down the connect button on the mouse for 5 seconds. Then release the connect buttons.
If you get the same problem, hold down both connect buttons (receiver and mouse) at the same time for 5 seconds.
Last, try to connect the wireless receiver into different computer. If you get the same problem, send the receiver and mouse to the manufacturer for repair.
Thank you and good luck!
Jun 15, 2010 | HP Computers & Internet
Wireless USB works, but mouse itself doesn't
Sir/Mam good day,
Is your mouse device also wireless? you need to resync it with it's receiver,
you may follow the methods below to make your wireless usb mouse works.
You need to press the button on your wireless mouse receiver, and make sure that the light on your wireless mouse
receiver blinks. But you need take note that some newer model of microsoft devices are permanently fixed to their receiver
and can't be reset. If your devices don't have a button, here's what to do:
If a dialog box appears on the screen in how many seconds, you need to follow the instructions from it. Or else, you need
to do this:
press and release the connect channel button on your wireless mouse, and make sure that the light from your receiver works
and the status on it's light is steady. If this happens then the synchronization is successfu. But if the problem is still
the same you need to repeat the previous steps once again.
As for the wireless mouse for notebook, this problem come out when the micro switch on the underneath of the mouse was not
released. You can use a pencil or anything with a sharp point to released it.
There are a lot of options why your wireless mouse receiver won't work, and a lot of solutions. Here's some of them:
*Try different ports on your computer, if the connection to some usb ports are not working you can connect to other ports
and see if it will work.
*And also the cables that are included with the wireless receiver, try to use another cables if the
device is still not working.
*If you're device is connected to a usb hub, disconnect it from the usb hub and directly connect it to
the available ports on your pc and see if it will work.
*When fixing this type of problem you need to have only one usb device
connected to your computer, which is in this case, your usb wireless mouse.
*When you have other usb devices, you need to
plug it out.
*If the methods mentioned previously still won't work, you need to reinsert your
wireless mouse batteries or install a new one.
*Another possible remedy to this problem is checking the interference, your wireless
usb mouse together with its receiver should be a distance away from anything that
transmits signals such as cellphones, radios or other similar devices. And also
any metal objects. because such things might interfere with the signal of your
wireless mouse.
* If the problem persists after doing all of the above steps, maybe it's time to update
your wireless mouse drivers, For installing latest driver update with your wireless
mouse, see the documentation that is included in your wireless mouse.
* If all of the methods above did not solve your wireless mouse problem. You can
connect your wireless mouse to another working computer to see whether the problem
lies with your wireless mouse or to the computer which your wireless mouse is
connected.
Final instruction:
If all of these methods fail, you better have your wireless usb mouse be check
by a professional computer technician in order not to further damage your device.
Hope this helps. Good luck and God bless
http://online-pcrepair.blogspot.com/
Jan 11, 2010 | Silver Jeans 1660-13SL Mouse
The lights on the receiver of my mouse are out and
Try connecting the wireless receiver into another USB ports of the computer or maybe try different computer, if the light did not turn on, then you need to contact the manufacturer and RMA the device.
Defective wireless receivers could be repaired. Buying a new one would just cost you money. Try to go for a repair first before deciding in getting a new one.
Thank you!
Dec 17, 2009 | HP Wireless Optical Mouse
Hi, I have the wireless mouse 3000 and I just changed my batteries but on the receiver I can't get the green light to work. I tried pushing the button on the receiver but nothing. Any idea? The mouse has...
Try putting the receiver in another USB port on your computer. If it still doesn't light, push the button on the receiver and the reset button underneath the wireless mouse (you might need a pen/pin to do this) for approximately 10 seconds at the same time. The receiver and the mouse should now be synchronized.You should be able to use your mouse and and receiver should be giving a steady green light. If not, you will have to consider that the wireless mouse receiver is busted.
Nov 27, 2009 | Microsoft Wireless Notebook Optical Mouse...
Just bought microsoft wireless optical mouse and no instructions with it how do you connect it
Hopefully it came with an install CD ? Firstly keep the old mouse plugged until this one works. Now install the software from CD. With PC turned off plug in the wireless receiver to a spare USB port and power back on. Make sure youve got good batteries in the mouse. Now press the button on the wireless receiver and the lights should be flashing. While they are flashing press the button underneath the mouse. They should now be communicating and the mouse should work. If all is well turn off PC and disconnect old mouse. If you didnt get a CD dont worry if you give me the model of it i can find the software on the internet. ...........cheers from Scott
Oct 31, 2009 | Microsoft Standard Wireless Optical Mouse
Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Jul 21, 2009 | Microsoft Wireless Optical Mouse
Microsoft wireless keyboard 6000 v 2.0 often stops working. No idea what the lights on the little wireless hub means as no instructions. Help files do not mention anything either. I have erases=d drivers...
Are your batteries in the Keyboard and mouse good?
On the receiver there is three lights. The "A" is the CAP LOCK light, The "1" is the RECEIVER light and the "F" is the F LOCK light.
You probably have gotten it working by now but here is a way to get it work if not.
Press the Receiver button a(and the lights will start flashing, then if its the Keyboard that isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If its the MOUSE do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Nov 15, 2008 | Microsoft Wireless Laser Mouse 6000 v2.0
I have purchased a Microsoft Wireless Optical Desktop 700 (Keyboard & mouse). I have plugged the wireless receiver in, and get a flashing green light when I press the button on the front. The green...
When you say you pressed the connect buttons on both the keyboard and mouse, do you mean you pressed the connect button on the receiver, and then you pressed the connect buttons on the mouse and keyboard? If not, then that's what you have to do. The 30 seconds of blinking on the receiver is normal, as it gives you time to find and press the buttons on the mouse and keyboard.
I hope this helps, and good luck!
Jul 16, 2008 | Computers & Internet
No Cursor
Did you register the mouse to the receiver? There should be a button on the receiver, the bottom of the mouse or both used to connect the wireless mouse to the receiver. Also, if you do not have a red light on the bottom of your mouse it may have a battery problem.
Jul 22, 2007 | Logitech Optical Mouse Plus Usb Port...
Logitech Cordless Mouse Logo
73 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
