Question about Olevia LT32HVM 32 in. LCD Television
FIOS remote with Olevia 532B12
I just had Verizon FIOS installed in my house and when the techs tried to get the remote to talk to my Olevia LCD HDTV 532B12 to work it had two issues. One is the FIOS remote won't turn the Olevia on and off. And the the remote will not control the volume on the Olevia either. The tech told me I just needed to get the remote code. Can you guys tell me what I need to do so the FIOS remote will control all functions on my Olevia.
  • Anonymous Mar 10, 2008
    I have fios and a 37inch olevia hdtv with exactly the same problems. any help out there?
  • Anonymous May 11, 2009
    our olivia so wont work with the fios remote and seems to have trouble with its own remote at times
    if anyone comes across a code that works pls but it on the web
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Posted on Jul 15, 2008
    New Friend:
The code 11610 worked for my tv and Xfinity remote.
Posted on Nov 23, 2014
Verizon FiOS now has a rev2 on of remotes that now support the Olevia TVs. The new remote manual has several codes for the Olevia line of TVs. You will know you have a rev2 remote if the play/pause button has a line between the two symbols, or by looking in the battery compartment, the label should say rev 2.
I believe if you go through the Verizon FiOS customer service phone service and report that your remote is broken, a new one will be sent out (automated process, no humans involved).
I just got a new box and it came with the new remote, and it works fine on my Olevia TV.
Posted on Sep 22, 2008
I also have FiOS, and an Olevia 532H and a new 242V. FiOS remotes do not work with the Olevia TVs yet. Now that I have the 242v, I thought I'd look around again, and Googled the solution - someone mentioned a Sony universal learning remote as their solution for $20.
Posted on Mar 03, 2008
I used the Yamaha code 0030. It will control the On/Off, Volume, and Channel selections, but that's good enough for me.
Posted on Mar 28, 2009
Need remote codes for olevia tv model 532b12
037,033,038,031. Try these codes. If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 13, 2013 | Syntax Olevia 532H 32 in. LCD HDTV
Cannot program Verizon FIOS remote with RCA L32HD31 32 in. HDTV LCD TV, none of the codes work. Can you assist?
Talk to Verizon,should not require code because u using verizon remote on verzon box.
Jan 15, 2010 | RCA L32HD31 32 in. LCD HDTV
No codes for remote verizon fios control of tv came with tv or are listed for RC1445 302/oob manual
for my tru-tech i used the auto code finder on the Fios remote instructions it didn t take very long, I can t say the same for my memorex tv though.
May 10, 2009 | TruTech PLV1615T 15 in. LCD Television
I can't turn my TV off with the Verizon FIOS universal remote.
Try the following codes. I know you stated that you were given codes so ignore any that you already have tried:
Verizon FIOS
Vizio 0891, 0912,1783
Alternative Codes
1758, 0178, 1756, 0128, 0117, 1017, 1078, 0030, 0056, 0205, 1292, 0057
Mar 31, 2009 | Vizio L32 32 in. LCD HDTV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
NEED REMOTE CODE
Go on the Verizon website and request a new remote, the Verizon P265 Remote model. It will have all the newest firmware and it should have the code. I know this because I had a TCL 32" TV and the code wasn't on my old Philips RC 1445302 model. TV and new remote are "talking" just fine now. Verizon won't even want the old one back.
Dec 05, 2008 | Universal Remote Control Remote Control
532-b12 code for fios remte
go to www.verizon.com look up fios tv and go to equipment and there you will find the codes for the remote
Feb 17, 2008 | Olevia LT32HVM 32 in. LCD Television
Remote code
Olevia 3131, 3226, 3231, 3232, 3233
Jan 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Olevia LT32HVM 32 in. LCD Television Logo
2,601 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
