Question about HP Color LaserJet 2600n Printer
Transfer belt replacement
Can you tell me how to change the transfer belt
  • jrudick Jan 08, 2009
    I have the same problem and the print quality is poor. Anyone know how to replace the belt?
  • 4,402 Answers
Didn't know it had one. whats the problem your having?
Posted on Jan 10, 2008
After BizHub C450 copier has stopped and said replace Transfer Belt, is there anyway to get back up running until new belt shows up
Remove the transfer belt unit and change the chip fuse on transfer unit.The fuse is or a little green pieces or glass fuses ,the value 0,065mA/250V rapid fuse.After change the fuse pull on the unit and turn ON the copier.Before change the fuse reset the transfer belt counter in the Present parts life mode.
Mar 29, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
C13C8 A new installation is not detected when a new Transfer Cleaner Unit (Image Transfer Belt Unit) is installed.
When a new transfer belt unit is installed in a machine an internal component on the transfer belt unit changes state; this now indicates that the transfer belt unit is used
Apr 10, 2012 | Konica Minolta bizhub 350 All-In-One Laser...
Remove transfer roller 4650
Just curious as to what prompts you to think it needs to be removed?
It is part of that transfer belt assembly that is on the inside of the front door that opens out and down ( hinged at the bottom).
I have only seen the entire assembly for sale.
Easy as pie to change if you feel the need but the machine should tell you when to change it.
go to youtube and search for precision roller , then HP 4600 trnafer belt.
They have a video showing how to remove it and replace it.
Ray Charles could do it.
They also sell the assembly.
Mar 14, 2012 | HP Color LaserJet 4650DTN Printer
Service 100 thousands miles
The 04 was pretty straight forward.
Change the oil and filter when the display tells you to. (Don't forget to reset Oil Life system!)
when the display tells you to change engine oil... Do the following as well:
~Lube Chassis Components
~Check Tires for Air and Damage
~Inspect Break System
~Check Engine Fluids and Washer System
~Check Power Steering System
~Check Wiper Blades
~Check Restraint System
~Lube Body Components (See manual)
~Replace Cabin Air Filter (Located in firewall on passenger side.)
Every 25K miles do the following:
~ Inspect Fuel System, Exhaust System, Accessory Drive Belts for damage or wear.
~ Replace Air Cleaner
Ever 50K Miles
~ If used for Towing - Replace Transfer Case Fluid :: If not change fluid ever 75Kk miles.
Every 100k Miles
~ Change Automatic Transmission Fluid and Filter
~ Change Automatic Transmission Fluid and Filter again at 150k if heavy service
~ Replace Spark Plugs
Every 150k miles
~ Change Engine Coolant (Or every 5 years which ever comes first!)
~ Replace Engine Accessory Drive Belt
optional y are supposed to change the transfer case fluid every 50k if towing
Feb 27, 2011 | 2005 Cadillac SRX
En toshiba e-3511 sale codido de error CEE0
CEE0: Transfer belt position detection abnormality (normal speed):
The home position of the transfer belt cannot be detected.
This likely means that your transfer belt has gotten ripped. There are reflective strips on the transfer belt that tell the copier what position the entire belt is in before copying, and when the transfer belt gets ripped it causes the machine to not be able to find these strips.
You will need to replace the transfer belt and it would be a good idea to change the belt cleaning blade as well.
Aug 30, 2010 | Toshiba E-Studio 3511 Color Copier
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Are you there? I have a problem with a Minolta 2200 as to the error about replace the transfer belt . Can you help
contact minolta tech support coz they will tell you how to change the transfer belt if you do not know any thing about printers get profeshinal help
Dec 23, 2008 | Minolta magicolor 2200 DP Laser Printer
Transfer roller
Use the keys on the control panel to select the following menus: setup|maintenance|check others|transfer belt|reset then press [enter]. The LCD should read "reset now" and the printer will return to the ready prompt.
This assumes the error message you have is for the transfer belt near end and not the transfer roller itself (which is NOT part of the transfer belt, it's actually attached to the RH door as you look at the control panel).
Oct 16, 2008 | Samsung CLP-500 Laser Printer
HP Color LaserJet 2600n Printer Logo
235 people viewed this question
Ben Johnson
