Question about Garden
WHEN i GO TO ENGAGE THE BLADE I GET AN AWFUL GRINDIING METAL NOISE
    President:
  • 1,627 Answers
Sounds like you need the bearing replaced that your blades bolt to,nothing else on the tracter would make that kind of a noise only when the deck is engaged.
Posted on Nov 18, 2009
Ceiling fan making grinding noise
bearings are dry and noise is metal on metal you can try to oil/lube the bearings --and or a blade is rubbing on case either loose blade or bearings worn causing offset wobble
Jul 13, 2016 | Dryers
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
I have a 91 toyota 4Runner and when I'm drivibg
doesn't mean the transfer case isn't still trying too engage.even with the front drive shaft out.
Sep 04, 2017 | Cars & Trucks
Blade spins and hits side of bowl
Get in touch with Kitchen Aid, that should not be happening.
Feb 19, 2014 | KitchenAid Food Processors
Loud noise when the dryer turns on
Well, sir, it is metal on metal, and you did well to stop it. Someone will be needing to take the whole thing apart and find the problem. It may be easy because the metal should show where it was rubbing because it will be shiny bright.
Be blessed.
Jan 08, 2014 | Samsung DV448AEE Electric Dryer
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
One blade cuts and one doesn't. Is this a pulley or a belt problem?drive belt sound hasn't changed. can belts be adjusted or only replaced? what tools are needed?
Set the thing up on some blocks and try to remove the blade which does not turn. Since your belt is working, the pulley must be spinning or there would briefly be an awful racket. If the pulley is spinning but the blade is not then there is something wrong with the mandrel/spindle, or the blade has come loose and has somehow not cut off anyone's foot. Sometimes the pulley and top of the mandrel become rounded out but again there would be some metal on metal noise. Often there is a star shaped protrusion on the bottom of the mandrel which locks into the blade and by virtue of hitting some immovable object, that unstoppable keeper has been destroyed.
Jun 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Jun 08, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
My Yard Machines MTD blade won't engage. The belt that spins blade is loose when I try to engage deck.
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Apr 19, 2009 | Garden
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
