Question about Brother PT-1750 Thermal Label Printer
My PT-1750 won't advance the tape when I print. There is plenty of tape in the cartridge.
4 Suggested Answers
  • 624 Answers
SOURCE: labeling system trouble-shooting
This is a duplicate post, click on the following like for the original: http://www.fixya.com/support/t133614-labeling_system_trouble_shooting
Posted on Mar 04, 2007
SOURCE: pt-110 problem
I have the same problem. There is a little arm attached to the base of the pinch roller. It's broken on mine causing the problem. Attempted to epoxy the part back together, did not work, part is too small where broken. Don't know if there is a replacement part. New P-Touch was $39.00 at Staples so I'll probably just buy a new one. You have to be pretty mechanically inclined to get the thing apart anyhow.
Dave
Posted on Sep 28, 2008
SOURCE: Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Posted on Aug 03, 2009
My ptouch 1750 gives me an error message that says "no tape!" but i have tape installed. help!
Hi, Make sure that the cartridge is installed and that there is no slack with the ribbon. You can turn the tape by advancing the tape in the center of the cartridge wheel, IN THE DIRECTION of the arrow on the cartridge. You can advance the tape by pressing 2 buttons: CODE and Space
Also if you installed a new cartridge, make sure that you removed the safety cover.
Hope this helps.
The owners manual can be found at this address:
http://www.ptouchdirect.com/ptouch/manual/PT1750.pdf
Have a good day.
Mac =)
Apr 22, 2013 | Brother P-Touch 1750 Label Maker
"no tape" error
I found 2 helpful manuals from brother that you may want to checkout. they explain exactly how to install the cartridge:
http://www.ptouchdirect.com/ptouch/manual/PT1000.pdf
http://www.ptouchdirect.com/ptouch/manual/PT85.pdf
Feb 18, 2013 | Brother P-Touch PT-2400 Label Tape OEM...
When I try to print with my Brother PT-1200 label maker, it says "ERR" and does nothing. I changed batteries and the label cartridge but still nothing.
open the back of the label maker. remove the cartridge. in the lower right hand corner of the where the cartridge fits, there are 3 little posts that are pushed in when you insert the cartridge. find the holes on the cartridge that fit over those posts. cover the holes on the cartridge with tape. reinsert cartridge. try again. worked for me. If you push in the posts individually, you can figure out which one is giving you the error message. I'm not sure that it really makes a difference. I taped over all three holes and it worked fine after that. i realize its not a perfect fix, but may allow you to print anyways!
Jun 08, 2011 | Brother P-Touch PT-1200 Label Printer
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
How do I change the font size on my p-touch 1750??
The shift and up keys together make larger type, while the shift and down keys together will make smaller type.
Oct 29, 2009 | Brother PT-1750 Thermal Label Printer
Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Doesn't print anything
My P-touch has the same issue. There is a U-shaped spring wire that pushes one of the rubber wheels so it presses the tape against the element that "writes" on the tape. A small piece of plastic that holds the spring in place broke off so the spring can't do it's thing. CA glue (superglue) would not work, I am trying to find a parts source now, it is easy enough to replace.
Mike
Jun 15, 2008 | Brother PT-1750 Thermal Label Printer
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Labeling system trouble-shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Brother PT-1750 Thermal Label Printer Logo
60 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
