Question about Canon PIXMA MP600 all-In-One InkJet Printer
Have the canon mp600 and like others it has the 6A00 error that won't go away. It had a paper jam and paper was pulled out- can't see if a fragment is left. May try the shaking technique- other solutions? Please?
  • 4,041 Answers
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Canon Pixma MP600. Have an 6AOO error problem. Tried various corrections, still no luck in resolving it.
The 6A00 is a Canon generic code for paper path jam. Somewhere in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if it is jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs Incidentally, the 6A00 error pertains to all Canon printers made in the last several years; it is not just used in one model. And it is always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has an electrical pump to milk the print heads and test for ink flow. Move back and forth several times (with the power off)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Canon PIXMA MP600 all-In-One InkJet...
How do I fix error 6A00 on my canon MP600 printer?
Hi there
This answers with a titch more detail.
Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code.
The offending item needs to be removed or the purge unit needs replacement.
Incidentally, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model.
And it’s always a paper path error or purge unit.
The purge unit, called a spittoon assembly in an HP, Lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Also clean the purge unit out make sure all is clean.
Apr 30, 2010 | Canon PIXMA MP600 all-In-One InkJet...
When trying to print, paper gets jammed, screen comes up with 'error code 6A00'
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Feb 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon Pixma MP600 printer has an error coming up of 6A00
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Jan 29, 2010 | Canon Pixma MP600 Printer
I have a 6A00 error code. Can you help me?
Solution 1:
Solution 2:
Solution 3:
Jan 13, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannon Mp600. I have an error code 6A00
Try
Solution 1:
Solution 2:
Solution 3:
Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer error code 6A00
Heello there
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Nov 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error code 6A00 on Canon MP600R printer
OK here is the codes
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Oct 20, 2009 | Canon PIXMA MP600 all-In-One InkJet...
The printer cites error 6A00. I'm told that this
With thanks to a canon tech :-)
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
May 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Mp600 error 6A00: After you check for loose paper
Hi
Error 6A00
Solution 1:
Solution 2:
Solution 3:
Apr 26, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
