Question about Whirlpool Duet GHW9150P Front Load Washer
When getting ready to do laundry, discovered about 3 inches of water in the tub. What causes it to happen when not in use?
  • 95 Answers
Leaking water mains on inlet solenoid
Posted on Nov 18, 2009
My washer sometimes ends up with a couple inches of water in the tub a day after last used. Also, at times water leaks on the floor. Neither of these things happen consistently.
It is likely that the fill valve located inside the rear panel is leaking, especially if you leave the supply lines turned on all the time. One annoying fix is to turn off the water supply after each laundry session but than you have to remember to turn the water on again next time
Dec 28, 2012 | Maytag PAV3240A Top Load Washer
Tip
The washing machine is draining but the water is coming back inside?
Check out this possibilities for water not draining in the washing machine: This problem relates to the hose connected to drain pump. The drain hose should not be in laundry tub more then 4 to 5 inches. Measure it and if it’s more then 4 to 5 inch then cut the excess hose in the tub. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly. But if the drain pump hoses are ok checked then this problem relates to slow drain of water from laundry tub. You can solve this issue by cleaning the drain pump blockages and dirt build up this will make the flow of water proper in the draining of the laundry tub.
This will help.thanks.
on Mar 18, 2010 | Washing Machines
Water accumulates in the drum
Hello there There could be a couple of different reasons why this is happening first look at this Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve Next Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. and last is the drain pump it'self if it is wearing out like they will eventually do it is time to replace the drain pump ok so please look into each of these and keep me posted on what you have found and i will send you some more information if needed Best regards mike
Jan 09, 2011 | Washing Machines
Hooover washer dryer not spinning
Check the brushes in the motor, replace if less than 3 or 4 mm long.
If prob still persists, then the control board is probably faulty.
However
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 29, 2010 | Hoover AAA140 Front Load Washer
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
After the clothes have spun dry, a small amount of water accumlates in the tub; generally 1/4 inch or so. Why BTW, I'm not sure that I've selected the correct model. Our washer is about 3 years old.
If draining into laundry tub, chances are water is siphoned back into washer due to laundry tub slow drain.
Very long drain hoses( such as 10+ feet) will also cause this.
Nov 05, 2009 | Fisher and Paykel IWL12 Top Load Washer
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
M9503 washer dryer not draining before dry cycle.
Check these out:
Aug 22, 2009 | Hoover AAA140 Front Load Washer
After the final spin cycle, my clothes are still wet.
Check these out:
Aug 21, 2009 | Hoover HTC243 Top Load Washer
HE3T Kenmore Frontload Washer Random Draining Problems
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
  1. Check the pump impeller for obstruction.
  2. Cut the drain hose into the laundry tub in excess of 4 inches.
Aug 21, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal De
