Question about Dishwashers
Door interlock switch
Can I run an Hygena washing machine with the interlock switch on the door bypassed until I get a new one, The switch has 3 cables , 2 large , one small, I have checked the switch with a meter and it does not seem to be doing anything , I would like to know if I connect the 2 large cables together would this allow me to run the machine or have you some other advice on this matter.
    President:
  • 1,314 Answers
The door interlock switches are safety switches so the washers stops when the door is open if bypassed and the door is open could be a mess and damage floor so let your mind be your guide its not recommend by factories who are damage minded hope this helps but it wold work i mean if such a condition existed the washer would run
Posted on Jan 11, 2008
Hotpoint washer wont work
From the manual page 24:
'Door' is flashing in the display window...
?Shut the door firmly, until it clicks.
The symbol should now go out.
I suspect the door sensor has failed. It thinks you haven't closed the door, so it refuses to do anything at all. It's called a Door Interlock, it has a switch or sensor built into it.
First try unplugging the washer for 60 seconds and plugging back in to try to reset the controller. (Dry hands only!)
If the door interlock is a simple switch, you should be able to check it with an ohmmeter. I would check it first before buying a new one.
The part number is HPTC00085194 or C00085194, here are a couple places you can buy one. You can also find them on ebay.
Washing Machine Door Interlockby Indesit
Door Interlock Washing Machine
WASHING MACHINE DOOR INTERLOCK C00085194 design may vary
Sep 21, 2016 | Hotpoint Ultima WF860 Front Load Washer
My washer doesn't start eventhough the lights is on and the door lock doesn't go on. i unplug and wait for 15-20 minutes and do the same thing. and nothing happens?
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 14, 2015 | Maytag Neptune MAH5500B Front Load Washer
My washing machine turns on and lights up and dosent do anything else
Apr 08, 2015 | Washing Machines
My whirlpool washer/dryer combo washer want run dryer works great
Mar 30, 2015 | Whirlpool Washing Machines
What is the de error message
Hi Prasanthi.
On front load machines, some manufacturers us de as 'door error'. This generally relates to a fault with the interlock mechanism.
This is the door lock which prevents the door from being opened while the machine is working..
If the door won't lock and/or the machine won't run. OR the door is locked shut, then this is the most likely situation.
The interlock switch is part of the electrical circuit.
NOT recommended for a handyman.
It's not a big job for a technician, and you will probably need a new interlock.
Good luck.
Nomess
Interlock switches look like this.....
Feb 09, 2015 | Washing Machines
There is power going to the washing machine but only sometimes the door lock indicater light turns on when the switch is on and the door is closed. The machine will work when the indicater is on and...
hi Sandra.
Yes it could be the interlock.
power is passed through the interlock on to the rest of the machine. The actual latching shut of the door is a simple spring-loaded mechanism where the latch just slips into the door catch and the door stays closed. Locking the door is a separate process.
go to this link and it should help you find out if it is or not.
How washing machine door interlock work How to test
Dec 14, 2017 | Candy CN136 Front Load Washer
Machine keeps saying error
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 16, 2009 | Washing Machines
Zanussi IZ 12 Washing Machine Front Load
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Need to bypass my interlock on washer to determin that is the fault
Remove 3 wire connector from the interlock unit. This has 3 wires one black and 2 white. Short out the sockets of the two white leads. Start machine and the door lock light on front panel will be on.
Jul 08, 2008 | Washing Machines
Dishwashers Logo
184 people viewed this question
Top Dishwashers Experts
