Question about Canon PIXMA MP460 All-In-One InkJet Printer
Paper jam error showing, but no paper jam in
I have a paper jam error showing, but no paper jam in printer. What can I do?
  • mccallnic909 May 11, 2010
    i have bought new ink cartridges and printer says cartridge unreconised
  • 4,041 Answers
Hello there
This could do the trick
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 05, 2010
    President:
  • 995 Answers
Possible causes of the problem:
- Tiny paper or something is stuck in your printer.
- Your printer roller may have dirt on it.
Solutions:
-There may be a very tiny bit of paper stuck somewhere - look very carefully. Also, open all areas and then close them - sometimes a printer has to have that before it resets from a jam. Check your paper to see if it is being grabbed by the rollers. if they are dirty or worn, the paper will not catch and the printer thinks it is jammed. wipe the rollers with a bit of alcohol on a paper towel (barely damp) if that is the case.
Posted on Nov 18, 2009
frcs68
  • 1605 Answers
SOURCE: Paper Jam error
try to open the cover and reseat the ink.
the machine is trying tell you there is something stuck inside where the switch or the senser is located. usually right before the heater path. after the paper pickup roller.
Posted on Oct 15, 2008
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
1alexh
  • 484 Answers
SOURCE: Paper Jam error will not reset after removing jammed paper
In many cases, you must use compressed air in a can, and blow out the insides of the printer. These printers use photoelectronic eye technology to tell you when there is no paper left, or other supplies are used up. But unless you clear that out by blowing air through and past those sensors, they do not reset. The paper dust continues to block the sensor which makes it report that there is no paper, that there is a paper jam, etc.
Try clearing it out that way.
-a.
Posted on Jul 02, 2009
Peoples book
  • 9 Answers
SOURCE: Paper jammed (Dell lase Printer 1720dn
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Posted on Aug 22, 2009
pineworks
  • 4041 Answers
SOURCE: printer error paper jam and no paper to be found!
Hello there
You may not see a paper jam.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Posted on Mar 30, 2010
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
Tip
How do I fix and avoid paper jam error issues in a Dell printer?
Fix and avoid paper jam error issues in a Dell printer-
Paper jam is one of the most common issues among all brands printers. Dell printers also show such issues and you will be indicated this error by the light or beep noise when a paper stuck inside. To avoid such issues on your Dell printer or fix the paper jam problem read here the useful tips that would be helpful to utilize Dell printing service with better efficiency.
Watch this video and fix paper jam issues in your dell printer: https://youtu.be/4nGBQ0H1RQw
on Feb 13, 2018 | Dell A940 All-In-One InkJet Printer
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
Hp laserjet 2015 printer shows an indicator light error that theres a paper jam but actually no paper jam or paper particles . I have cleaned aii the sensors and checked the paper path. Powers on well...
restart it
if problems insist check if sensors are working
if are working you need to replace motherboard
of your printer that cost to high
you better replace your printer
hope i had help you
Nov 26, 2010 | HP LaserJet P2015 Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
379 people viewed this question
old marine
old marine
