Question about Fujitsu Siemens AMILO Pro V2000 Notebook
External monitor amilo pro v 2030
Can someone please tell me do u need software to get an external monitor connected to my laptop as i have tried everything thanks
  • 13 more comments
  • eamonn1 Jan 10, 2008
    yes i got a vga connector and i got a lead that goes from this to the tv but i cant get it to work, im not much into computers
    is this only solution for my problem
    the menu on my tv? i ve installed the lead between them then pressed fn and f3
    No its not a computer monitor its a tv set. it has a s-v input on the front of it which i have plugged into then i changed the tv to channel AV3 which is a black screen and doesnt change no matter what i do
  • eamonn1 Jan 16, 2008
    still havent got it working
  • eamonn1 Jan 17, 2008
    tried all avs on my tv still no better, do u think i need sowtware or a device to change picture
    which post tom and can you please explain what i have to do in steps so i understand better, dont u think i need software or something, or maybe a differant tv , sorry for all the trouble im putting u through, im very grateful for your help
    yes have tried that as well , do you think its right lead i have
    i dont know wat my adaptor is tom the computer said it can display to an external monitor and i got that lead as shown thats all i know
    i dont understand when u say the cable needs a special display card, how do i know wat i have
  • eamonn1 Jan 18, 2008
    yes have a lead to extesd with two male ends
    ive tried it as metioned before ive installed cable etc.
    no i get nothing on tv when i try this it just makes a slight noise every time i press fn and f3
    yes have an s video and the rca coloured jacks on tv
Think i need a secondary display adaptor it tell me wats this is it one that will plug into slot in my computer
Posted on Jan 18, 2008
    Master:
  • 788 Answers
You will need to make sure that your refresh rate is set to 60Hz or the TV might not be able to read the signal. Go into your display properties, on the settings tab, click on the advanced button. Go to the Monitor tab and ensure you are on 60Hz for your VGA output. Select the proper input on your TV and you should see your picture. You may also need to switch display outputs on your notebook usually done with the function (fn) key and F5 or F6.
Posted on Jan 10, 2008
  • 589 Answers
I wonder if by "tv" he means just a monitor. He should be able to use the FN + F5 to toggle in between the LCD and the external monitor.
    Genius:
  • 1,601 Answers
If you have a blue vga connector on the laptop ,you should be able to change to an external monitor through the bios.
  • 13 more comments
  • Thomas Christopher
    Thomas Christopher Jan 10, 2008
    You need a vga converter to get it to work with your tv.
    like this.
    http://sewelldirect.com/pc-to-tv.asp
    it dependson what connectors are on your TV. there are different ways to put your pc signal on tv. Look at your tv and then look here on ebay (cheaper price) for an adapter that has the same connections as your TV. You already know the connection on your PC (vga)
    http://search.ebay.com/search/search.dll...=
    When you hook it up to your tv you go into menu and change source, such as video1 video2 ,etc.
    you need a source for the signal to the to the screen. there is a way to set it through your menu or buttons on the remote.
    Thomas Christopher Jan 17, 2008
    change the tv to another channel AV?
    See my jan.10 post. it looks like the only way.
    This is what I am referring to.Its no bother...
    This adapter will ONLY work with VGA display cards that has TV-Out function capability. Does yours have this?
    **This cable needs special necessary display card (For example: G400, the NV6 series by superior, etc) supports the VGA signal, transforms the S signal or the AV signal, without this function this cable can not be able to use
    Does your tv have rca jacks on it? Try hooking the red and yellow to them.
    it looks right... keep playing with the combo...
    It needs a jack like the black end on the adapter
    Thomas Christopher Jan 18, 2008
    plug those into the input to the TV
    You have the vga connector connected to the computer, the monitor refresh rate on 60 hz,and the two RCA jacks to the tv. You switched the signal to the tv from the laptop.
    you tried to get a picture on the tv by switching the video inputs on the remote or tv setup. do you get anything on any tv input source when you try it?
    Did you say that you had a s video jack on your tv?
    Plug in the s-video and try messing with the seetings
Use external monitor
To switch to an external monitor you need to use Fn F4.
Jan 11, 2014 | Acer Aspire 1500, 1620 and Travelmate 240,...
The display on my Amilo Pro V2030 is black after it fell on the floor. Does this necessarily mean that the display is dead and needs to be replaced or external monitor used? Could the problem be fixed in...
May be a loose connection, at best, at worst, HDD damaged, etc., etc., etc.. Does it boot? Fan spins? LED's Blink? Sound? Anything? If you connect a External Monitor does it work? There are cable at the bottom and rear of the monitor that can come loose.
May 04, 2013 | Fujitsu Siemens Amilo Pro V2030 Laptop...
Laptop is working but the monitor is black. I connected with another monitor but still the same problem. What should I do? Thanks.
Fn+ F7 should allow you to toggle to the external monitor. If not then you have a video chip/card problem.
Apr 19, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
How do I open my Amilo pro V3515? I think that the contact to the display or the graphic card has gone off or half off .Beacuse when I put on my laptop the display is black and the computer does not start....
Visit the below link that has manuals of laptop:
http://support.ts.fujitsu.com/com/support/manuals.html
Type your laptop model amilo pro v3515 in search box in the manuals and select your language English to get the manuals of your laptop that contains removal and replacement procedures of laptop parts.
Jun 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Amilo Pro V2030 - Wont Boot
Try connecting it to an external monitor as the display may have gone out on you.
Feb 12, 2009 | Fujitsu Siemens Computers & Internet
External monitor problem Amilo Pro V2000 laptop
right click desktop go to graphics properties then at the top it will
say single in the top box click on the one underneath and make
sure the displays are:
1:notepad
2:monitor
hope this helps
Sep 19, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
External monitor for amilo pro v2030
hi
when the external monitor is connected hold down the function key " f n " ( which is located 2nd on left of lowest row ) and then press either the F4 or F5 function keys on top line....the one that has a small icon like a rectangle or tv screen on it ....it has usually 3 toggle positions so if it dosent work first time then just press the same key again (still holding fn key) until it allows the monitor to get the signal.....if F4 dosent work then go thru the same sequence with F5 but depending on the laptop model it could be any one ...F3/F4/F5/F6 the usual suspects....
hope this helps
Jan 04, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
451 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
