Question about Canon PIXMA MP830 All-In-One InkJet Printer
My MP830 just flatlined. Checked plugs, peeked inside (found a stink bug)but everything seems in place. What would cause it to work fine one day and be dead the next. It didn't sputter or pop or wheeze..nuttin...just dead.
My 2006 Jeep Liberty CRD just stopped running while driving. I had it towed to a garage and they found stink bugs in the air filter so they cleaned everything out. Now they are telling me that the...
Sounds right to me ...sorry to say it but there aren't many other things that stink bugs could have messed up being sucked into the motor. (What a rush huh?) lol...
Aug 08, 2011 | 2006 Jeep Liberty
Samsung RB215BSSB refrigerator freezes up
I had a similar problem where my evaporator coil was freezing into a block of ice, which caused my fridge to warm up due to a lack of air flow. I fixed this by doing a few things. I replaced the circuit board ($100) which was easy to do. Unfortunately, this didn't fix my problem so I took the inner fridge cover off to view the evaporator/heater coil assembly. I checked my thermo fuse and found it to be open (failed). I ordered the thermo fuse and the thermistor and replaced them both. I then plugged the fridge back up and put a regular thermometer inside the fridge to get an accurate reading of inside temp. A few days now and everything looks good. The board, fuse, and thermistor were all pretty easy to replace.
Apr 09, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
Canon MP830 power outage while printing
My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
To might great relief my MP830 powered up and is working just fine.
Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830
My Canon mp830 is under warranty, so I took it to an official repair place rather than try to sort out its problem myself. I understand these are sensitive to power fluctuations. Mine may of experienced this. If you wish, I will get a detailed explanation for you of what the repairman found wrong when my mp830 is returned to me.- Melody
Apr 17, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Does not work
I believe what happened is that when the wrong adapter was connected it damaged some of the electronics inside. Specifically I would guess some filtering capacitors. You would need to open it to fix it. If you need the data I would think that the drive inside would still work so you could take it out and get the data off of it. Otherwise I would see about sending it back for warranty replacement.
Nov 02, 2007 | Maxtor One Touch III 500GB FireWire/USB2.0...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
20 people viewed this question
old marine
old marine
