Question about MTX Thunder 421D Car Audio Amplifier
Sub not working and red light on amp stays on?
I have two JL audio subs mounted in power wedge enclosure hooked up to a MTX thunder 4300x amp. One sub speaker has no sound and the amp has a red light that is always on?
    Sergeant:
  • 188 Answers
The amp is under to much pressure get a bigger 1
Posted on Nov 18, 2009
My mtx thunder 421d I just got has the red light staying on all the time, I have hooked up a rca converter and the amp wont play my sub, is that light supposed to be red all the time.
The LED should be red. If you are not getting power to the sub, make sure the speakers are connected properly to the amp. Also make sure that the gain control is turned up. If it is all the way down, you will not hear anything from the sub(s). If none of that works, it is possible that you have a blown sub. If you smell a burnt smell near the speaker magnet, there is damage to the voice coil in the sub.
Feb 25, 2011 | MTX Thunder 421D Car Audio Amplifier
I installed a MTX Thunder 3401 with a PA sub. after turning the car oh every things works great. After about 2 mins of play, the thermal light begins flashing red and it will shut off the amp. After the...
You are def overheating, If the ohms rating of the subwoofer is too low it will cause this same thermal over heat. If you have 2ohms in sub and a 4 ohms stable amp, you will overheat. Check the ohms rating of the sub to make sure this is not the problem
Jan 31, 2011 | MTX Thunder 3401 Car Audio Amplifier
Can you bridge 2 4 ohm kicker speakers to a mtx thunder 7801 amp?
Ya. Just hook one sub to your amp (bridged) and hook the other sub (positive and negative) to the first subs positive and negative
Nov 12, 2010 | MTX Thunder TA7801 Car Audio Amplifier
MTX 81000D amp doesnt work
Have you checked to make sure your sub is wired correctly to the amplifier?
May 30, 2010 | MTX Thunder 81000D Car Audio Amplifier
Amp and sub have been working great together then all of a sudden the amp is not putting out enough power to push the sub. MTX Thunder 311D
check to see if one of the RCA cables is unplugged or bad. check the gain check the sub level control on the deck if yours has one.
May 19, 2010 | MTX Thunder 311D Car Audio Amplifier
2 MTX Thunder Problem.. Bridging?
Is there a option on the chanels that say ''Bridged''? If so, you can hook the subs up in parellel or series to get different ohm loads. Usually the lower ohms, the more power amp puts out. Those subs can handle 225 watts RMS whitch means the power it can handle constantly. If the amp gives more than 225 watts RMs, you could be at risk of blowing the sub. If you could give me the model # of the amp, I can be of more help.
Feb 11, 2010 | MTX Thunder 4500 T4510-04 Car Subwoofer
Setting for...
HI DUDE .. U CAN ONLY SINGLE PC OF JL SUB BY BRIDGE MODE ... COZ UR MTX AMP HAVE 300WATTS RMS ....
Apr 05, 2009 | Alpine MRD-M301 Car Audio Amplifier
Help connecting the sub
Your sub or amp is probably blown. Do you get any power to the amp? try hooking up another speaker and seeing if you get any signal at all.
Jun 24, 2008 | MTX TA4501 Thunder 4501 MonoBlock Car...
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
MTX Thunder 421D Car Audio Amplifier Logo
375 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
