Question about Refrigerators
Can this refrigerator be used in an unheated garage?
  • Refrigerators Master
  • 1,606 Answers
Depending on the brand . A refrig thermostat , is designed to cycle off at 38-42 degrees . If your " unheated " area , gets below 38 degrees , then the refrig will thing the temp is cold enough , and will not cycle on , therefore , the food in the freezer WILL thaw out and probably ruin .
If your brand cycles on the freezer thermostat , then the " unheated " area , will be ok .
Posted on Nov 18, 2009
  • 43,501 Answers
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
4 Suggested Answers
  • 1073 Answers
SOURCE: I have a refrigerator in
it will not work in sub freezing temps, the thermastat will not kick on if the temp is below 34 thus the freezer coil will thaw and anything is the freezer will melt, anything in the fresh food section below 32 will freeze 60 or below not recomended
Posted on Apr 15, 2008
jtbjtb
  • 135 Answers
SOURCE: freezer not working in garage top mount freezer on refrigerator
Sears is technically correct. It wouldn't work with the old coolant either. The principle is simple. The refrigerator is the same temp as your garage - it is not running. It must be in a 60 degree room to work properly. The sensor to turn it on is in the fresh food compartment, and it never calls for cooling; therefore it appears you freezer only is out - but they both work together. Hope this helps!
Posted on Feb 17, 2009
  • 670 Answers
SOURCE: HAVE A GE PROFILE SIDE-BY-SIDE
You need to put a heat source in the fridge compartment near the fridge thermostat. Try putting a lower wattage bulb (40w) into the fridge compartment. Or even try this, take the door switch out of the fridge and short the two leads together. Tape the exposed ends with electrical tape and that should provide enough heat to keep your compressor on long enough to keep the freezer cold. Just remember to put the switch back in in the spring and summer months or you will have a real high electrical bill. Hope this helps you.
Posted on Dec 08, 2010
Fridge is kept in unheated garage. Freezer doesn't work during winter months and everything unthaws?
Thermostat is typically in refrigerator section. So if it's say 32 in garage and knowing that temperature is measured in refrigerator, compressor has to run very little or not at all to satisfy thermostat in refrigerator. Thus freezer doesn't get much colder than refrigerator because compressor doesn't have to run.
Nov 14, 2017 | Refrigerators
CAN I PUT THIS REFRIGERATOR IN THE GARAGE??
yes of course you can they even work when in an unheated garage
Jan 25, 2016 | Refrigerators
Can any make of freezer be used in garage. Told only Beco
Refrigerators are designed to be used inside at typical to normal household temperatures. The problem with refrigerators are if the ambient temperatures drop down below 55 Degrees F Food in freezer will begin to defrost when the temperature in the garage goes below 55 degrees Fahrenheit. The fresh food section may begin to freeze food slightly below this temperature. If you live in an area where the outside ambient temperature does not get below 70 degrees F or 20 degrees C then the refrigerator will work fine but to have it located in an area where temperatures drop well below this you could lose some food. There are heaters that can be adapted to the compressor if used in an unheated area. Hope this helps, Sea Breeze
Jul 05, 2012 | Whirlpool Freezers No Refrigerator Model...
NEW KNMORE REFRIGERATOR/FREEZER. UNIT IS A TOP FREEZER AND STS IN AN UNHEATED GARAGE. FREEZER FAILS TO FUNCTION WHEN TEMP GETS BELOW FREEZING IN THE GARAGE.
Yup, Many refrigerators will not run if the ambient temperature is below like 36 F. There are some good reasons for this that would take many pages to explain...
heatman101
Jan 17, 2011 | Kitchen Ranges
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Side by side refrigerator in unheated space not working in cold
Good day,
GE recommends minimum ambient air temp above 55 degrees,
and that's pushing it.
Move it inside.
As an example. If the garage temperature was 10 degrees and the machine was left unplugged. What would the temp be in the fresh food section. If you said 10 degrees, you would be right.
P.S. Insulation does not prevent an area from getting cold, it just delays the time.
Nov 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
Sep 15, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Freezer not working in garage top mount freezer on refrigerator
Feb 17, 2009 | Kenmore 64522 Top Freezer Refrigerator
Cold garage interferes with top freezer keeping cold enough
Sorry it took awhile but there is not a cold area kit for this refrig available. it needs to be used in a controlled climate so that the controls will operate properly thanks for your patience. Peyton
Jan 27, 2009 | Frigidaire FRT21H8 Top Freezer...
New Fridge/Freezer placed in Garage,when ambient temp falls freezer stops working
You do not say what type of Fridge/Freezer it is. Some types will not work in cold ambient temperatures, ie unheated garages.
Check the user instructions, if it does not say anything about this, get onto the service department for advice.
Dec 08, 2008 | Refrigerators
Refrigerators Logo
230 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
