Question about Frigidaire FDB1502RG Built-in Dishwasher
My Frigidaire dishwasher will not start.
My Frigidaire FDB1500LFSO dishwasher will not start. The door is properly closed and the ''Heat Dry'' button is lighted, but nothing happens when I press any of the buttons.
This model wasn't in the list of valid products.
  • andrew_newel Nov 21, 2009
    I had to hire a repair man for this. It turns out that the control panel needed replacing.
No solution, just a big thanks about that tip on holding down that 'Heat-Dry' button. Worked like a charm.
Posted on Oct 23, 2010
This solution worked for me too. Thanks for the money saving solution!!
Posted on Feb 06, 2010
WOW! This same thing is happening to me tonight too! The Lock button is lit for me but not the "heat dry". Looking forward to reading what this problem is.
Posted on Nov 21, 2009
  • 1 more comment
  • Mom232 Nov 21, 2009
    I found the answer and mine is working now!!! Hold the "Heat Dry" button for 5-7 seconds and the "lock" light should go off. Then hit start/cancel or delay start!
    OH! I really hope that it did!!!! Mine's working great now!
  • raymundo_rui
    raymundo_rui Mar 27, 2013
    yes it works, thanks for the simple solution... i love the internet
Holding the "Heat Dry" button down for 5-7 seconds worked for me too - THANK YOU for posting this solution!
Posted on Jan 13, 2010
  • BeHandyNow Sep 27, 2010
    100% solution in holding the "Heat Dry" button down!!! Thank You!
I have frigidaire dishwasher model # FFBD2411NS. It stopped working as if it had no power. I switched the breaker swith to shut if of then tut on. After that the lights above the "high temp wash" and "heat...
Hello Marcus, since you have already reset the dishwasher, confirm that the door is properly latched and try selecting a cycle. If resetting the power did not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance. I hope this information proves to be helpful in some way.
Aug 04, 2013 | Frigidaire FFBD2411NS
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
The lights will blink when the door is closed and the start button is pushed
Try a reset. I have a kitchenaid. The reset is to press the sani-rinse, hea-dry, sani-rinse, heat -dry, then close the door. You can hear action the dishwasher doing something. Takes about 2-3 minutes, then stops. At this point I was able to select a wash cycle and start, close the door, and it started. Good luck
Feb 05, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
My model number is FDB1500LFSO, my dishwasher quit...
Is the door open or unlatched?
Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if it believes the door is not latched. Check for obstructions (spoons, etc), interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure.
Is there power to the dishwasher? Electricaly ground dishwasher. Connect ground wire to green ground connector in terminal box. Do not use an extension cord. Failure to follow these instructions can result in death,fire or electric shock.
Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
Does your dishwasher have a rotary timer knob? (Some Models)
The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
Is the control lock option activated?
Press and hold the Heated Dry option (button with lock icon) for five seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
Is the delay start option activated?
To cancel the delay and cycle, press Cancel/Drain.
Has the motor stopped for less than 10 minutes?
The motor may have stopped due to an overload. If this is the case, the motor will automatically reset itself within 5-10 minutes.
Is the Start/Resume indicator flashing?
Opening the door or interrupting the power can stop the cycle. Close the door and press Start/Resume. If the Start/Resume indicator flashes three times when you press Start/Resume, the dishwasher is waiting for you to open the door after the last cycle. Open and close the door, and then press Start/Resume.
On models where the controls are on top of the door be sure to close the door within 3 seconds of pressing the Start/Resume to start or resume the dishwasher cycle.
Is the water shutoff valve (if installed) turned on?
Make sure that the water shutoff valve is turned on.
If these tips did not work or your controls are not working correctly you may need to schedule service.
May 17, 2010 | Dishwashers
The lock symbol located at the dry button is lit and the dishwasher wont start on my built in Frigidaire fdb520rhso
check your door lock make sure it has correct voltage and has not been closed indicating that it is locked.other than that replace the control board
Mar 12, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
The clean button keeps blinking, will not go off and i cant restart to wash. i hit the heat dry button for six seconds and it was unlocked but i cant get the washer to restart.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 21, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Lock light is on
The lock only locks the buttons (childproof), hold it 3 seconds and it will go out.
Jan 18, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
My Dishwasher does'nt dry my dishes.
How old is the dishwasher? Check the front control panel for a AIR DRY / HEAT DRY switch. Perhaps the switch is in the AIR DRY position. If so and you really want to HEAT DRY your dishes, set the switch for HEAT DRY. Otherwise: Second, it is not a bad thing to let your dishes AIR DRY. It saves money! Just open the Dish Washer door after the last rinse cycle has finished and let the dishes AIR DRY manually. In a hour or so they can usually be put away. Works for me :)
Nov 30, 2006 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire FDB1502RG Built-in Dishwasher Logo
3,167 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
