Question about Olympus EVOLT E-410 Digital Camera
When i take a snap after taking the snap it shows no memory . when the memory is insected .
Are there clothes that actually repell mosquitoes?
Apparently there are special clothes that are designed to repel insects: http://www.insectshield.com/work/Casual-Wear-C18.aspx
Jan 17, 2013 | Camping, Backpacking & Hiking
My sny cyber shot DSC-W120 camera doesnot allow me to take snaps at my memory card rather all the snaps stored at internal memory, which leads for maximum 5-10 snaps. How to avoid this, so that i can take...
Hi!
Please follow these steps in order for you to store snaps in your memory card by default:
  1. Press HOME
  2. select Manage Memory > select Memory tool
  3. Press Change REC. folder then select your memory stick or the folder which you want to save your pictures to.
Thanks!
Jun 13, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I have 1Gb card in my a470 power shot. It was having around 600 snaps. Yesterday i clicked abt 40 snaps but later only latest 8 r visible. Computer memory shows 956 mb out of 1024mb. i am not knowing what...
I may not be totally understanding the question but from the numbers you supplied I'd have to say the memory card was full and could not save any more mb to the card. It might be at the point where it's not showing a "FULL" message on the screen but full enough that it can't take anymore pictures. Another thing is there is always space used by the memory card (operating system) that requires space so out of a 1gig memory card you only get about 950mb of storage space. If you are missing pictures it is possible that they are in the camera internal memory.
Feb 11, 2011 | Canon PowerShot A470 Digital Camera
WHILE I AM TAKING SNAP IN MY NIKIA N70 PHONE IT IS NOT SHOWING/ SAVING IN GALLERY
Do a hard reset :
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. So, backup all of your data in phone memory. Enter *#7370# from standby screen and the standard code for nokia phone is 12345. After that, backup all data in memory card to PC. And then format your memory card. Good luck.....
Dec 26, 2010 | Nokia N70 Cellular Phone
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
Just bought it from Argos. Not installed a memory card but the Internal memory shows "Memory Full" sign after taking 1 picture. Additionally, the Available number of shots left is just 1 instead of at...
Almost all modern digital cameras have little if any internal memory. That which they do have is usually only their to be able to demonstrate the camera's features to customers trying them out in shops, etc. It is standard practice to use removable memory cards as this allows easy transfer to computers, printers and digital picture-frames. Also if you were going away on holiday and fill the memory it is simple to replace the memory card with a fresh blank one and carry on taking snaps.
I recommend you get a 2GB 'SD' memory card to start you off. They are very cheap these days compared to recent years.
Oct 19, 2009 | Sanyo VPC-S1080 Digital Camera
Memory stic
   Use only memory stick recomended by the company, which you can buy from any nearest SONY DISPLAY CENTRE or SONY SALES DEALER.
   Normally ppl use comman memory cards which shows working in the camera but when you shift the data from your camera to your pc the snaps show blurry, or bad images.
  Therefore,Dont bother to spend little bit expensiveness but it keeps your precious snaps safe.
Hope you will understand my sayings.
Thanks for using FIXYA!.
Take care. Bye
Feb 01, 2009 | Sony DCR-DVD608E DVD Camcorder
HELP ME PLEASE!!!!!!!!!!! I CAN'T GET IT APART!!!!!!!!
Have you removed the battery, and checked for screws there? Looked under the memory cover. Chgeck the the two halvers of the shell are not 'snap' together?
Jun 24, 2007 | Acer Aspire 3003WLCi Notebook
Format Error in Sony DSC-650
Please try with new memory stick. If it does not help please claim for an in warranty repair. If you need more info please advice.
Apr 12, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Olympus EVOLT E-410 Digital Camera Logo
23 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
