Question about Honeywell HE360A1027 Whole House Humidifier Humidifier
I have a carrier furnace, humidifier valve popped fuse
I have a 90+ carrier furnace and I installed a by-pass type humidifier. I figured I would use the existing wiring which was powering a drum type humidifier but the 3 amp fuse popped on my furnace board from the load from the water solenoid on my new humidifier. I don't want to increase the amperage of the fuse. Do you have any ideas? The new humidifier came with a 24 volt transformer but then it would require to be tapped into a "furnace demand" circuit somewhere.
Thanks for your help.
  • g_patucci Nov 19, 2009
    I figured out what I needed to do. I saw that there was a male spade terminal on the board labeled as HUM1.
    I used my voltmeter and watched the voltage on this terminal while the furnace went through its start up sequence. It read 5V, then when the flue motor came on it went to 6.5V, but when the gas valve opened, it rised to 26.5V.
    So, I connected the humidifier water valve (Humidistat)to this terminal and the Common terminal and all is well.
    Thanks for your assistance though.
  • Honeywell Expert
  • 252 Answers
Hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Posted on Nov 18, 2009
I have a carrier weathermaker 9200 - Water is leaking from under the furnace. I have checked the humidifier and in the furnace itself and cant find where the water is coming from. The furnace runs and...
Chances are it's from the condesate tubes or collector box. If not, you may have a cracked A/C drain pan- lots of installers over tighten the male adapter into them and cause cracks. next check to see if they installed all the condensate plugs at install, some installers don't- read the manual in the "how to set up the condesate" section and trace EVERY tube to make sure they are routed correctly and not cracked/ cut/ nicked. Most furnaces are multi-position now and some installers don't move every tube nessessary... Hope this helps, if not, post a close-up pic, and I'll pinpoint the bad spot for you...
Feb 22, 2013 | Carrier Humidifiers
If i hook my Aprilaire 400 Manual (not auto/digital) humidifier up straight to a 24v wall outlet instead of to the furnace, will it still work correctly? Or does it need to be powered by the furnace to...
Your humidifier is a bypass type. The only voltage needed is 24vac to open the water valve. Air only flows through the humidifier when the furnace blower is running, and the wet pad will add very little humidity if the furnace is not running and heating the air before flowing through the wet pad in the humidifier.
It is best the water valve is only energized when the furnace is running. Some furnaces have a connector on their control boards labeled HUM for this purpose. Test it's voltage when the furnace is running because some will output 110vac instead of 24vac you need.
Jan 31, 2013 | Aprilaire 400 Humidifier
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
I have a Carrier humidifier model #HUMCCLBP2217-A. It appears to be working, but every time it shuts off it emits a very loud "thump". The noise is loud enough to wake me up at night. I have...
Do you feel like looking at the humidifier yourself?
You can open the door on the unit, while the furnace is running--
The humidifier is usually installed in the return air duct, so there will be a sucking of air into the open door, when you open it.
There is usually a large wheel, with a wet pad wrapped around the circumference.
This wheel rotates slowly, and picks up water from the sump-- does everything look and sound quiet as it runs? -- The float valve has to open and close, to c ontrol the leve of water in the sump-- (The pool of water the wheel runs the mat thru--
Possibly the valve shutting off, could make a plumbing BANG-- you could duplicate that, by lifting the float mechanism and stopping the water-- does that make the noise?
If you can reach and operate the Humidistat control from near the humidifier, do so a few time-- or Have someone cycle the humidistat a few times, and you listen for that sound--
Is it in the humidifier itself, or the duct work nearby?
It might be that the humidistat wheel scrapes against the side of the sheet metal duct work? -- Sounds travel a long ways in metal duct work!
Let us know if this helps
Mack B
Jan 19, 2011 | Carrier SBP Humidifier
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
I have a Honeywell HE225A humidifier installed on my Trane furnace. Due to water noise the solenoid on the unit was disabled and a new solenoid was mounted in the rafters to eliminate the noise. This...
This posted question is exactly one year old, but I just got this solenoid valve assy from ontimemall in Phoenix AZ. I don't have the receipt right here, but it was about $90. It is classified as: honeywell 32001639-002 solenoid valve.
Dec 08, 2009 | Honeywell Humidifiers
Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
Nov 22, 2008 | Carrier SBP Humidifier
Honeywell HE360A1027 Whole House Humidifier Humidifier Logo
653 people viewed this question
Top Honeywell Humidifiers Experts
Dennis
Simon Benzekri
Level 1 Expert
jdthefixer
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
