Thick Dark Line on received and copies of faxes
When I receive faxes it comes out with a very thick dark line running through left hand side of the page.
How can I get rid of this.
  • 610 Answers
Don't know the model of machine, but usually caused by the drum unit or toner cartridge. many machines have both drum and toner in 1 unit. try replacing.
Posted on Nov 18, 2009
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Faxes received have thick vertical dark lines
Make a copy of something to tell if you have a bad toner cartridge
Feb 04, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
Our faxes are being received with a large/thick
Look on the glass where the scanner is and sometimes a lot of White out gets stuck on the glass, clean with windex and dry good.
If it's a lazer fax, look on the rollers for toner build up around the fuser section. Clean with Alcohol.
Oct 16, 2009 | Office Equipment & Supplies
PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Dark vertical lines
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Feb 18, 2009 | Brother FAX-8070P Plain Paper Laser
Dark line
If the line is not on your recived faxes then you need to clean the area the paper passes over when sending. any marks could cause this.
Mar 19, 2008 | Brother IntelliFAX 2600 Fax
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
