Hi our church copier has decided to print one copy at a time, can you advice us how to get it to print multiple copies ita a ricon aficio 1013f cheers dorothy
  • creations_em Nov 19, 2009
    Thanks for the help but the problem I think is some one has touched other buttons and we dont know how to set it back to multible prints and when your printing things like church magazine its painfully slow.
    Cheers Dorothy
  • creations_em Nov 21, 2009
    yes thank you but dont know were the set up menu is or how to access it cheers Dorothy
    Sergeant:
  • 329 Answers
On some copiers, and` the Aficio is one, when you need toner it allows you to print one copy at a time untill you install toner.
Posted on Nov 19, 2009
  • Jim Keysor Nov 20, 2009
    If I understand you right when you punch in like 5 copies it says 1 and only prints one right? Or you punch in 5 it says 5 and prints only one, Right? This one is how the out of toner feature works. In the set up menu there is a way to disable that feature and print more than one, untill it runs out of toner and goes lite...Please advise.
Very dark copy
dark copies or background on the copies
if back ground on the copies need to replace the PCU unit
Apr 07, 2014 | Ricoh Aficio 1013F Copier
Is it possible to do two sided copies with this printer? If so, how can i do that?
as far as i know this can not make a two sided print automatically, but i think you can make a two sided copy manually. first copy the first side then return or place the paper on the by pass tray then print the second second side. hope this help
Sep 07, 2010 | Ricoh Aficio 1013F Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
How to set factory default at Ricoh Aficio 1013F
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Jan 04, 2010 | Ricoh Aficio 1013F Copier
My Ricoh Aicio 1013F is showing a duplicate shadow on the copy.
This is almost always the hot roller and/or the pressure roller bushings in the fusing unit. The Hot roller in this model is rated for 90,000 copies, but they commonly fail earlier than that. The pressure roller bushings also wear as they are made of plastic. If you can drag your finger across one of your copies, and the toner doesn't stick to the paper, then you definitely need bushings.
Check how many copies you have by press the "user tools/counter" button in the upper left of the control panel. You should see the word "counter" on the display. Press the "OK" button near the display; this will show you your copy count. If you are near the 75 to 80,000 mark (or multiples there of [150- to 160,000, etc.]), I'd say it's time to replace the hot roller.
Unless you are certified to work on these machines, you would need to get a service technician to do this. These particular machines are more difficult than some of the larger models, and I definitely would not suggest anybody try this repair unless they know exactly what they are doing.
Dec 15, 2009 | Ricoh Aficio 1013F Copier
How can I print from Tray 2 on Ricoh Aficio 1013F
It needs to be added within the printer driver.
In The Printers/faxes dialog box, "right click" the "Aficio 1013F", click "properties" click the "accessories" (or "change accessories") button, and add tray 2 as an option, Click "apply", and exit the utility, now you can manually select tray 2 when printing.
Feb 20, 2009 | Ricoh Aficio 1013F Copier
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
How do I stop information page from printing out?
(Reports on/off)-Key operator tools,user parameter,switch03,bits 0 and 5 set to 0.That should do it.
Jun 17, 2008 | Ricoh Aficio 1013F Copier
Text "ghosts" or shadows
Replace Drum or blade(if possible) will fix on most types of copiers/printers, or rarer it is cause of fuser.
Oct 19, 2007 | Ricoh Aficio 1013F Copier
jasbo
jasbo
