Question about Jura Capresso Impressa F9 Espresso Machine
My f505 jura displays fault 8 and the tray doesnot go inside.....i tried to start without the grounds tray, still the same problem...
2 Suggested Answers
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
How do I fix tray empty message on Jura capresso z6?
RB5193 wrote: If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch.
finally found it - look inside the large opening where the entire tray part fits - all the way up front - just inside the opening, not in the back where the contacts fit, but way in front - there resides the white micro switch - loosen it up and voila! It works (after 4 hours of hunting, scraping, filing etc - it works like a charm - photo attached, I hope. Thank you RB5193!
Jul 03, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
I have a jura capresso impressa f7 machine and when I cleaned it (using cleaning tablet) it made some strange sounds and the screen reads "Fault 8" - I removed the tray and cannot re-insert it as the...
Check to see if there is a lever that may need pushed in as you put the tray bad in...not sure as many of the machines are different...but it's worth a try! :)
Jul 30, 2014 | Jura Capresso Impressa F7 Espresso Machine
I have the Jura Impressa F50, the machine will no longer function when the coffee grounds conatiner is in place. I have reset the machine several times, have put the container inr\ different positions and...
on the tip of the tray there are metal contacts that tell the machine that the tray is installed. try cleaning these contacts with steel wool and on the inside of the tray with soapy water and a brush. remove excess water from tray and try
Apr 14, 2014 | Jura Impressa F50 Classic Automatic Coffee...
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
I have a Jura Impressa F50 model. I have the indication Error 8. I can insert the tray and the dump box but then the machine makes a loud noise and finally indicates error 8. I can remove the tray and...
This is the 2nd time in a month since I've had this machine that I had to call support for the same problem. An easy fix! I was instructed to remove the whole 'drawer assembly' and remove the grounds bucket. Insert the assembly without the bucket. Wait a minute, take it out again and replace the bucket. Then you're ready to go. Hope this helps.
Dec 16, 2010 | Jura Capresso Impressa F9 Espresso Machine
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Jura impressa f9 malfunction 8 i need help whats that
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Jul 08, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
Feb 08, 2008 | Jura Capresso C1300 Coffee Maker, Espresso...
Jura Capresso F7
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Dec 30, 2007 | Jura Capresso F8 Espresso Machine
Jura Capresso Impressa F9 Espresso Machine Logo
216 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
