Question about General Filters 1099-LH Humidifier
Not getting enough humidity in our house in the winter resulting in cracks in moldings, etc. Level drops to 15-20% without use of portable electric humidifer. 2 Story great room, 3600 sq. ft. house...2 furnaces...2 general aire humidifiers (model 1099LH and 1042)...checked all lines and water flow into humidifiers (everything checks out)...was thinking of adding a second humidifier for the furnace that handles the main floor in-line w/ 1099LH...thoughts?
  • jaustindds Nov 18, 2009
    Could it work out if I took the drain line from the first humidifier from above and ran it into the top of the second humidifier in order to simplify installation? Thanks, John
    President:
  • 1,515 Answers
Good Morning, as I was reading you're problem, the answer you gave is the solution to the problem as I was going to recommend the same option. Having gas furnaces, and as we know heat does rise to a certain degree, you most definitely need the humidity more so in the cold winters.I would get the second for the lower floor in line with you're other. This will help tremendously. Good Luck on this and time will tell. This is the right choice. Sincerely, Shastalaker7
Posted on Nov 18, 2009
  • Robert Horton
    Robert Horton Dec 17, 2009
    Hi, I wanted to thank you for the great rating you gave to me and hope you continue to use us here at FixYa as we do have some of the best tech's around.
The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Jan 14, 2011 | Vicks V4500 1 Gallon Humidifier
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
Hi I need help understanding the controls to my humidistat. I have a honeywell a/c unit so I'm assuming the gold colored humistat next to it is also honeywell. I bought a digital temperature and humitiy...
The higher the % of RH, (relative humidity), the more humid the house will be. I would disregard the temp part of the dial, and focus more on your comfort. Adjust it up daily until you reach a satisfactory humidity level. Hope this helps
Dec 19, 2009 | Honeywell Power Humidifier: Furnace...
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
Won't humidify past 30% in a 90sf bedroom
The most probable reason that the humidifier does not reach the levels you describe is because you said you had the unit in your bedroom.
Bedrooms typically contain materials that are known as "hygroscopic." What that means in plain English is that items such as the bedding, mattress, any carpeting, wood, curtains, you, etc. all absorb moisture , kinda like a sponge. Since that moisture is being held by these materials, the air itself contains less by percentage. 25-30% humidity is actually pretty good for any room, especially in colder climates and higher humidity levels can lead to the production of mold, condensation on windows, etc., which are not good things. The good news is that reasonable humidity levels are healthier for textiles such as carpeting, cloth, and so on because the fibers won't dry out and crack. Dust is also reduced, but again, only to a certain level.
If your humidifier is reaching 30% it's probably working ok.
Mar 27, 2009 | Hunter 33201 Humidifier
Aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Jan 26, 2009 | Humidifiers
Works too well, can't stop windows from sweating!
I don't know much about humidifiers other than they are rarely needed and most folk around here would rather there was a lot less humidity., especially considering how easily black mould grows and how injurious to health that can be.
Those few people living with an unsuitable heating system in a badly designed house usually find it is adequate to have a water feature in the lounge or to balance a bowl of water on a radiator.
Certainly when the windows sweat to such a degree, especially if you have double glazing, the humidity must be well above the comfort range, above 70%, and probably well into the moist range of 80% - 90%. Higher than that and any exertion becomes decidedly unconfortable...
I am guessing the humidistat is either faulty or cannot work because the humidity is already too high. I suggest you need to check the humidity in your home with an accurate independent humidity meter before you go further...
Mar 24, 2017 | Honeywell HE220A1019 Whole House...
Lack of humidity
Try the following test, ( I will resume this is a flow through humidifier)
Spray water directly oin the filter make sure it is saturated. Some water should leak from the bottom. After 10 min measure the Humidity to see if this helped. If there is a higher level of humidity the pbm is that not enough water is saturating the filter. Check the level of the filter & water feed nozzle.
Option 2 is to connect the water feed tube to a Hot water source.
Hope this helps.
Dec 28, 2007 | Honeywell HE220A1019 Whole House...
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
General Filters 1099-LH Humidifier Logo
174 people viewed this question
Top General Filters Humidifiers Experts
Paul Carew
jdthefixer
Steve
Are you a General Filters Humidifier Expert? Answer questions, earn points and help others
