Question about Ovens
When toasting top heating element not getting hot
  • 126 Answers
You may have a blown element. Unplug unit, take broil element out, and test it for continuity. Most appliance stores can test it if you cant. Bring your model # with you to order a new one if necessary.
Posted on Nov 19, 2009
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Is the top heating element inside the oven supposed to get hot even if not set on broil?
Yes the top element does get hot even on bake but it does not get red hot just hot. It will get hot enough to burn you so be very carful.
Apr 06, 2011 | Kenmore Ovens
Slow to heat on convection mode, bottom element not get as hot as
Check to see that the convection element is heating. If not, ohm it out, either the element is bad or it is not getting power from the control.
Jun 25, 2010 | Frigidaire 30 in. Electric Gallery Series...
My oven still doesnt work after replacing heating element
it could either be a hot spot in the element where it can no longer pass all the current needed for proper operation in heating(look for a discolored spot on it,it may be whitish and dimpled from heat) or secondly,it could be the oven thermocouple located on the inside top of the oven cavity
Feb 22, 2010 | Amana AEW3530DD Electric Single Oven
The oven, which is mounted on the wall next the the stove, doesn't get hot. I had an elecrician in and he said it wasn't the heating element. In fact he said the heating element for the broiler is working...
1. There are 2 elements, bottom one is the bake-element, top is the broil. Does the bake element glow when it cycles on?
2. The temperature sensor could be faulty.
3. The control board may have failed. We see this symptom frequently due to a control board problem. We repair these at www.fixyourboard.com
Oct 08, 2009 | Kenmore Ovens
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven and stove top not getting hot.
The most probable cause is that the heating elements are getting 110V instead of 220V. Check the voltage to the heating elements.
Sep 07, 2007 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
