You can use the optical output on the back of the unit to hook up to the input on the surround sound system. Via "Optical". That would be your easiest method of getting surround sound. You will need a optical line from somewhere like Walmart. Just ask for a 6ft optical cord.
You should find a Phono output on the back of the TV. Some even have a Digital Optical output as well. Depending what inputs your surround system has you should be able to hook it up to one or the other.
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
if your trying to use the dvr still your probably not connecting it all properly. make sure that. having a sony trinitron you have alot of connections on the back. if you connect all of the accessories that you have on your tv directly into each input and use the tvs main output connection to connect straight to your surround sound. this should fix your problem. plus you wont have a bunch of stuff hooked up to your surround sound receiver
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Make sure that your patch cables are cumming from the audio line OUT of the TV to the audio line IN on the surround amp. A common mistake on hook up is usually the problem.
