Question about Kodak Easyshare C813 Digital Camera
I have tried several new batteries,and camera wont turn on.for some reason the batteries and flash button become very warm...
    Genius:
  • Kodak Master
  • 1,099 Answers
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 18, 2009
Camera will not switch on in operate mode.
Can you test the voltage of the charged batteries, often they will not hold full charge for several reasons, age, factory imperfection, over use, haven't been allowed to discharge fully before recharge, dirty battery contacts, if you can, try new non rechargeable batteries, often cameras get temperamental about batteries after some time, use a metal tarnish cleaner with a cue tip, on the contacts, or pure alcohol, if bad, use plastic scourer, cold batteries don't work well, warm them in your hands if cold.
Nov 28, 2014 | Samsung WB150F SMART Long Zoom WiFi 14...
My digital camera is Samsung Galaxy, Model no is EK-GC100 and it won't turn on.
When the camera is becoming warm while charging the battery, the battery must be charged. So no need to check for dirty contacts. If you have a multimeter perhaps you can measure the voltage on the battery. While just measuring the voltage, the battery must give a little more then printed on the battery. So when on the battery is printed 3,7 V toy should measure 3.8 or 3.9.
Anything less means the battery is not good.
Now the causes of not switching on. Sometimes the on / off switch is defect. Sometimes the (mini) USB connector is defect and telling the camera, there is still a plug in the camera. It won't switch on. Sometimes the display button must be pushed several times, so the display shows something. And sometimes, the camera is defect.
Carefull investigate the connector and on / off switch, but be aware cameras sometimes become defect, without telling you what is wrong.
I wish you luck.
Nov 10, 2014 | Cameras
Wont turn on
If you think this has to do with the battery power, you also should check the contacts in the battery compartment. If the are not shiny, you can try to clean them with a dry cloth or a cotton swap. Don't use sharp tools in or close by a camera.
Make sure the battery is inserted correct and the battery cover should be locked correct.
If the camera was not used for a long time, perhaps some contacts are oxidised. Those contacts you can switch, try to switch them several times. Open and close the battery door several times. Press the on of button several times. Put the battery in and remove it several times. And hope the contacts will work again.
Mar 23, 2014 | Kodak EasyShare M883 Digital Camera
YN 565EX wont firing
I don't think this looks like any camera. But I know you can use this on a digital camera.
If the 565EX stops after 11 flashes, it could be it is warm. It could be the overheat sensor is a little bit to quick to respond. There also could be a problem with your batteries. If they run low in a short time, they cant deliver enough power to charge the Flash.
Try new batteries and be sure you charge them correct. Using an old charger with new (high capacity) rechargable batteries, is asking for trouble, because the old chargers can't charge modern batteries to full capacity.
Nov 06, 2013 | YONGNUO Cameras
The function button on my d40x i think is sticking because when i turn my camera on the self timer keeps flashing and when i try to access the menu or any other functions like playback it wont allow me the...
Since you can't get into the menu, let's try a manual reset. Remove the card and the battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Nov 23, 2009 | Nikon D40x Digital Camera
The camera wont turn on
hi...ensure that the camera is turned on. If applicable, ensure the lens cover has been removed before taking pictures. the LCD backlight is turned on by pressing the DISPLAY button several times until the screen appears. Depending on the camera model, the DISPLAY button may be labeled as DISP or with a display icon. This button could be a standalone button or it depends upon the camera model.....
If operating the camera with a battery, ensure the battery is fully charged.
Ensure the battery is inserted properly in the camera.
If operating the camera with the power adapter, ensure it is plugged into a working AC outlet.
Ensure no Audio/Video (A/V) cables are connected for viewing pictures on a TV; the LCD screen will not display when an A/V cable is connected.
Perform a reset procedure on the camera....
Apr 04, 2009 | Kodak EasyShare C743 Digital Camera
The Flash will not work
1. Turn on the camera.
2. Set the camera to Still Image mode.
3. Press the Flash button to cycle through the flash settings and select the one you need.
The flash range: 3 ft to 6.7 ft (1 m to 2 m).
To find Find Flash button, see user manual or download it here
http://lv.diplodocs.com/jim/POLAROID/A500-_E
Feb 15, 2009 | Polaroid A500 Digital Camera
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
ClickSmart 510 Will Not Be Turned On
make sure the terminals the batterys go into arent dirty, thats usually one of the main reasons a camera wont function. hopefully it works out, good luck
Aug 23, 2007 | Logitech ClickSmart 510 Digital Camera
Empties batteries in 2 minutes
please insert a new pair of batteries and check weather the camera starts in proper manner. does the flash charges. normally even if the camera operates and switches on in proper manner but if there is any problem in the flash section the flash does not fires or do not charge. and if there is a short circuit in the flash section that will result in warming and consuming up the batteries in no time. the heatin of the batteries itself indicates that there is a short curcuit in the camera.
Jun 20, 2006 | Nikon Coolpix 4600 Digital Camera
Kodak Easyshare C813 Digital Camera Logo
141 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
