Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Says there is a paper jam on my hp L7480 but there isnt
5 Suggested Answers
SOURCE: hp 6110 says there is
open the rear access door and clear the rollers,
Disconnect the power cord from the product.
Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
Posted on Jan 22, 2009
yooperbud
  • 8637 Answers
SOURCE: My HP 1610 thinks there's a paper jam - when there isnt one.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 1218 Answers
SOURCE: hi, I have hp 1410
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Posted on Oct 14, 2010
  • 1218 Answers
SOURCE: HP Officejet L7480 false paper jam message. Resett...
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Posted on Oct 15, 2010
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Paper jam--how do you pull the paper out?
Please open this LINK and follow the instructions. You'll also find some helpful tips about Paper Jams HERE.
Hope this will help.
Good luck.
Thanks for using FixYa.
Aug 03, 2011 | HP L7480 Officejet Pro MFC All-In-One...
I have had this printer for almost two years and the Document Feeder has never worked. It is getting tiresome. I have cleaned the rollers and the paper feed but it still jams when I try to feed a...
Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts, you can actually get a brand new printer half the price that you will see on the website plus you can also get an extra year of warranty just by adding $1.00 to the total price of the printer.
Feb 13, 2011 | HP Officejet Pro L7480 All-in-One...
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Says there is a paper jam but there isnt - have looked and looked - can I overide it?
Possible problems:
- Tiny paper or something is stuck in your printer.
- Your printer roller may have dirt on it.
Solutions:
-There may be a very tiny bit of paper stuck somewhere - look very carefully. Also, open all areas and then close them - sometimes a printer has to have that before it resets from a jam. Check your paper to see if it is being grabbed by the rollers. if they are dirty or worn, the paper will not catch and the printer thinks it is jammed. wipe the rollers with a bit of alcohol on a paper towel (barely damp) if that is the case.
Nov 18, 2009 | HP Officejet Pro L7480 All-in-One...
Paper jam, but no paper..
could be a hard ware problem..check your warranty
Apr 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Problem with paper jam, but no paper..
1) there should be problem of interference of another signals.
Hp 2355 all in one error message
reset to factory defaults, also check the whole printer for paper jams. A paper jam can often casue smaller pieces to get stuck in gears or rollers. The message about opening and closing the lid is how the printer knows you went in to check it and closeing it triggers it to try again. If thers still a jam it will keep giving the message. The fist jam was caused by something, check and make sure there isnt any pieces of plastic broken off inside. If it has a rear access panel, check there also.
Feb 16, 2008 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
42 people viewed this question
Seeker5211
Seeker5211
