Question about GE (PSS26MSRSS) Side by Side Refrigerator
My ice maker is pooring out water. How do you stop the water from pooring out?
    Sergeant:
    Champion:
  • 289 Answers
Unplug frig,if water still come's in than you have a bad inlet valve and nead to turn water off.if water doe's not come in than you nead to unplug ice maker and plug frig back in.if no water come's in than you have a bad ice maker.in most case's you are better off buying a new ice maker.
Posted on Nov 18, 2009
My ice maker stopped making ice...is there anything i can check myself to correct this problem
If the ice maker has completely stopped producing ice :-
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly:-
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Check this link for your knowledge:-
http://www.partselect.com/refrigerator+icemaker-no-ice+repair.htm
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Sep 30, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Ice maker in Kitchen Aid stopped making ice
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
May 09, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replaced icemaker with new one but still not working
Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
LG refrigerator french door icemaker not working
Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
Jan 06, 2009 | Refrigerators
Ice maker won't quit dispensing ice cubes don't have ice skates!
Dec 11, 2008 | Amana Refrigerators
Ice maker stop making ice for kenmore 106.56352500
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
Oct 10, 2008 | GE Refrigerators
Ice maker stopped making ice
hi,
Oct 03, 2008 | Whirlpool GS6NBEXR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
