Question about TurboChef TORNADO Electric Oven
Oven door sqeaks and is hard to open all the way . Is there a way to adjust the hinges on the door? Everytime you open it, it makes a sound like metal rubbing on metal
    Scholar:
  • 75 Answers
Adjusting the oven door is best left for a factory trained tech. There is alot involved with getting the hinges and monitor switches working together in harmony. alot of times the bottom grate on the front of the oven rubs on the door and usually gives you the metal on metal sound. the bottom grate just pulls off. Then see if its still rubbing. Be sure that the oven door has all of the screws and they are tight before calling for service. There are 3 screws on the left side and on the right side without them you will have problems.
WARNING: Procedure should be done while
oven is hot. As a result, exercise extreme
caution when adjusting the door.
good luck Sean
Posted on Nov 18, 2009
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
Door to oven does not close completely - how do I access the door hinge to check or replace it?
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Jan 02, 2011 | GE JTP45 Electric Double Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Decor double oven - Door adjustment
Unfortunately yhe door hinges are non adjustable.
The only solution is to replace the hinges as a pair.
Hope this helps.
Dec 15, 2009 | DCS WOS-230 Oven
The door no longer closes correctly leaving a gap at the top. When open it is no longer horizontal but falls to a downward slant
It sounds to me that the oven door hinges need to be replaced, especially if it is a drop down door
They need replacing as a pair.
There is no povision made for adjustment on hinges.
Hope this helps you.
Dec 08, 2009 | Miele H340-2 BP Pyrolytic Electric Single...
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Oven door zbf360x zanussi
Open the door half way, grasp it firmly and pull as hard as required using a slight side to side motion to release the hinges which are attached to the door.
There are then to nuts on the bottom of the door which when removed allows you to split the door in half.
The hinges have a little lever on them such that they can be jammed open against the door. Once the hinge hook is in the oven housing simply turn the latch the other way, stand back and have a beer.
Feb 14, 2009 | Zanussi ZBF360X Electric Single Oven
Re Neff B1451 oven door not sealing against oven body at top
If you take the hinges off, you can fit some washers between the hinges and the door to make it close it further. Probably not as good as new hinges, but cheaper. 2mm of washers will close a 5mm gap
Dec 30, 2008 | Neff B1451 Single circotherm plus Electric...
Oven door won't close tightly
Sounds like whoever installed your oven hasn't adjusted your door properly and as a result over time probley got worse? any way there should be 3 screws on each hinge the top and bottom screws hold the door in place the screws under the top ones are used for making adjustment with a Philips head screw driver open the door and try screwing in clockwise 2 or 3 full turns and with your free hand feel if the door is moving upward if so repeat the same on the other side and then close the door and see if its made a difference if so and its still loose try again if its made it worse the turn the screws in the opposite direction Let me know if this works
Dec 09, 2017 | Whirlpool RBS305PD Electric Single Oven
Smeg Double Oven SD08
this can be hard to do as you should have locked the hinges with the door fully opened before taking it off. the hard part now is (with the door off) you have to push the spring loaded hinges down and lock them with small hook located on each hinge once locked the door will go back on the oven. you then open the door fully and unlock the hinges, good luck
Feb 17, 2008 | Smeg DO81CSS Electric Double Oven
TurboChef TORNADO Electric Oven Logo
255 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Shehu Pro
Shehu Pro
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
