Question about Peachtree Software Peachtree Complete Accounting 2004
I get an error message saying Peachtree database engine has encountered an error. To correct restart the computer. I have done that & it makes no difference. I can't get into my Peachtree program at all.
    Guru:
  • 1,738 Answers
Make sure you meet the software reuire specs on your computer.
Posted on Nov 18, 2009
Tip
How To Run Data Verification In Peachtree Accounting
<p>Data Verification is a Peachtree utility that allows you to verify if any of your data files are missing or possibly damaged. During the verification process, Peachtree makes any needed changes so that your data records are compatible with Peachtree data formats. For example, if an ID in a data record has more than the maximum allowable characters, Peachtree will truncate the ID. Also, any files that Peachtree finds to be corrupt and unusable are deleted during the verification process. <br /> Following verification, Peachtree generates a log that details all errors encountered and reports on any changes made, as well as any corrupt records deleted. Follow these steps to run the test:<br /> <ol> <li>In your company, from the <b>Tasks</b> menu select <b>System</b>, <b>Change Accounting Period</b>.</li> <li>Highlight the first <b>Accounting Period</b> on the list and click <b>OK.</b></li> <li>From the <b>File</b> menu, select <b>Data Verification</b>.</li> <li>Select the <b>Both Tests</b> (recommended) option from the menu and click <b>Start</b>. <br /></li> <li>You will be prompted to make a <b>backup</b> of your Peachtree data. This is a required step. Click <b>Save</b>. The data verification test will begin automatically when the backup is complete.</li> <li>If no errors were found, click <b>Close</b>. If errors were found, you can examine the details of the tests by clicking the <b>View Error Log</b> button.</li> <li>To change back to the current Accounting Period follow steps 1 and 2 above.</li></ol>
on Feb 21, 2011 | Computers & Internet
Did recovery, error message: encountered unexpected error
If you made backup recovery cd's do a fresh install of the operational system to factory setting.
Apr 17, 2012 | eMachines EL Computers & Internet
Cannot open Peachtree Complete Accounting 2007 as error message states cannot connect to pervasive 9
Apparently your Peachtree system is linked to Pervasive database stuff.
It is possible your system remotely connects to pervasive or you have pervasive software on your machine. It is possible that you subscription to their service ran out OR a change has been made to your Pervasive stuff or computers it operates on that has made it impossible for your Peachtree software to access the databases it is tied into.
If you connect to Pervasive remotely, then check your internet access and subscription status.
Nov 10, 2009 | Computers & Internet
Peachtree Complete for DOS on WIN 98 says GL not found
Run command prompt as administrator. Enter chkdsk /f as command
Suspect reinstallation of the Peachtree program would necessarily follow that. What points to the G/L file was corrupted by the power failure. If you can uninstall Peachtree without loss of the data, the forementioned may fix the problem. sAfter all, if the error message is that the Programs for GL are not found, reinstallation should replace those programs. I think Peachtree 11 was an update which worked on XP. Note that one person tried to update to XP Pro from Home XP and it took Peachtree 11 hours to make the transition. Gives you a bit of a pause. Set up backups if you use Peachtree. Hope these ideas help. There was a Peachtree for Dummies book written in that period, FYI,
May 31, 2017 | Peachtree Software Computers & Internet
Using Peachtree Complete Acctg 2003 w/ Microsoft Vista
may be need to reinstall it again then make update for it
Dec 09, 2008 | Peachtree Software Peachtree Complete...
BCM Problem ... Lost Contacts
The BCM uninstallation doesn't delete your databases. They should still be on your computer here:
C:\Documents and Settings\<username>\Local Settings\Application
With either a *.mdf or *.ldf extension. Those are SQL databases which you can get the data off and into a CSV file which you can import into outlook (of course technical expertise is needed) or you could more easily (once the problem with BCM is resolved), make BCM re-recognize the databases by following these instructions:
1. Go into BCM and create a new database. That database needs to match the
name of the .MDF file. So if the MDF file is named "MyBusiness.MDF", create
a new BCM Database with that name
2. Stop the MSSQL$MICROSOFTSMLBIZ Server by going to Start > Run >
services.msc and selecting the MSSQL$MICROSOFTSMLBIZ service
3. Copy the original .mdf & .ldf files over the blank database. They should
be in the following location
Data\Microsoft\Business Contact Manager
4. Start the Server again (see step 2)
5. Restart BCM and see if you can access your data
which I found here (credit to Larry from the Lockergnome's forums).
If you could write what the error message is I could possibly help you resolve the BCM problem you're having, thereby making it easier for you to view the data on the SQL database files.
Dec 31, 2007 | Microsoft Outlook 2003 for PC
Peachtree Software Peachtree Complete Accounting 2004 Logo
747 people viewed this question
Top Peachtree Software Computers & Internet Experts
Are you a Peachtree Software Computer and Internet Expert? Answer questions, earn points and help others
