Question about Extreme Networks Altitude 350-2 (15939) 802.11a/b/g Wireless Access Point
Where do i set the password to do telnet onto the APs
    Problem Solver:
  • 12 Answers
Microsoft's site goes into detail with telnet,
http://technet.microsoft.com/en-us/library/cc787407%28WS.10%29.aspx
Posted on Nov 18, 2009
Sannce DVR-DH81NK1T i am lock out need code or password
Connect dvr to local network
boot up the dvr
connect to local network with a computer (eg Mac)
login into admin screen of your router to identify the assigned ip address of the router
start a terminal session
telnet to the ip address
default user name : root
default password : xc3511
mbaad@MBAADs-MacBook-Air:~$ telnet 192.168.0.3
Trying 192.168.0.3...
Connected to 192.168.0.3.
Escape character is '^]'.
YourCCTVDVR login: root
Password:
BusyBox v1.16.1 (2014-12-24 15:47:14 CST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
Welcome to Monitor Tech.
[root@YourCCTVDVR /]$ cd /
[root@YourCCTVDVR /]$ ls
bin etc linuxrc proc share usr
boot home mnt root slv var
dev lib opt sbin sys
[root@YourCCTVDVR /]$ cd mnt
[root@YourCCTVDVR /mnt]$ ls
custom dvs logo mtd usb web
[root@YourCCTVDVR /mnt]$ cd mtd
[root@YourCCTVDVR mtd]$ ls
Config Log
[root@YourCCTVDVR mtd]$ cd Config
[root@YourCCTVDVR Config]$ ls
Account1 StorageCfg network
HvrMode SysComs ppp
Json SysTime resolv.conf
RT2870STA.dat dhcp.cfg uboot_env_lang_video
There will be an Account## file for each account you have set up
Remove all of these files
[root@YourCCTVDVR Config]$ rm Account1
Reboot your dvr box and it is at the first setup screen
Here are the commands - note you can't send password as part of the telnet command
telnet 192.168.0.XX
root
xc3511
cd /mnt/mtd/Config
rm Account*
exit
CCTV Networking Technical Support
Apr 10, 2017 | Home Security
Which Default Passwords Are Used on S Series Switches?
On the S series switches of all versions:
· When you log in a switch through a console port, no default user name or password is provided. The system asks you to set the user name and password when you log in to the switch for the first time.
· Before you log in to a switch through Telnet, create a Telnet account.
· You can set the Telnet login authentication method in the VTY. If the password authentication mode is configured, set a password in the VTY. If the AAA local authentication mode is configured, set the user name and password in the AAA view. If the remote AAA authentication mode is configured, set the user name and password on the AAA server.
May 27, 2016 | Huawei Computers & Internet
Telnet password night owl dvr
By trial and error I guessed the telnet password. I found a not that said it's running a version of Linux.
Here ya go!
regular telnet (not ssh)
root/123456
Apr 02, 2013 | Night Owl Optics 8 CHANNEL H264 DVR WITH 8...
Where is the password located at
Hey, the Netopia routers do not have a default username and password. If a password is already set up, you might need to reset the router.
In order to log into the router you need to Telnet into it.
If you are using Windows XP, you can start Telnet from Start>Accessories>Communications>Telnet
if you are using Windows Vista or Windows 7, Telnet is not enabled by default. You need to enable it first. You can quickly re-enable Telnet by following these steps:
Start
Control Panel
Programs And Features
Turn Windows features on or off
Check Telnet Client
Hit OK
After that you can start Telnet via Command Prompt. (or the Start menu)
then once you get into the Telnet Console, type in:
192.168.1.1
and the router interface will open up and let you chanfge settings.
[CLICK HERE] for the official Guide by Netopia.
Sep 23, 2011 | Netopia (3347NWG-ENT) Router (3347NWGENT)
How do I turn off Telnet on a Ricoh Aficio 2020D?
I think that the easiest way is with the WebImageMonitor (Web Interface).
Open your browser and write the IP adress of you machine (ex. http://192.168.x.x/)
Then you must login as administrator.
User: Administrator
PW: password.
Then go to network settings and disable the telnet
Apr 12, 2011 | Ricoh Aficio 2020D Copier
How to reset password of username in 6506e switch through telnet not console plz give reply as early as possible.
login through telnet, remove the current username and password.
configure the username with the new password
config t
username xxxx pass xxxx
1. do not exit the current session, telnet the sw with new session and give the username and new pass. if does'nt work roll back the config.
or
2 excute login in current session and try with the username and new pass
Feb 21, 2011 | Cisco Catalyst 6506E Switch Chassis...
Can't telent to belkin cable router model f5d9230-4
You are trying to set up the router with the Telnet connection. I think it is a DSL connection.
Are you able to go online when connected to the telnet modem only ?
or do you have user name and password for the ISP.
Click Here for Step by step solution
Oct 28, 2009 | Belkin (F5D5231-4) Router
Lanier ld122 503 service unavailable
This can occur if the Web services has been turned off in either the Web Image Monitor or from a telnet command for this device.
To check the status of these services you will need to telnet into the device.
1. From a command prompt type : telnet then the IP Address of the device
2. Telnet will respond back with a request for a login and then a password. Enter the login and password. The login and password used for Telnet are the same credentials that are used to log into the device’s Web Image Monitor (WIM).
3. Type in show at the msh> command prompt.
This will output many lines of information. The information you are concerned with is under the TCP/IP-Mode heading. You may need to scroll up in the command prompt window to see these services. The device’s services will be shown followed by their status. The ‘show’ command will show if the services are enabled (UP) or Disabled (Down).
4. If Web shows a down status, at the command prompt msh> type in set web up.
5. At the command prompt msh> type in logout
6. To make your changes Active you must type yes when prompted to "save configuration data"
Note: Always check with your system administrator before making any changes on a network device.
Aug 19, 2008 | Ricoh Office Equipment & Supplies
Computer
On the controlled pc you must open administrative tools - services and make sure telnet service is started and set to automatic.
On the controlling machine, open a dos window and type "telnet computer-name" or "telnet ip-address" when prompted enter username and password that is valid on controlled pc, at that point you can run many dos command line commands and programs. Make sure that controlled pc has passwords for all accounts, otherwise you open a big security hole.
Apr 06, 2008 | Microsoft Windows XP Professional With...
Reset a password for IBM NWAYS Router 2210 Model 12E
Does this mean anything to you Remote Login Names and Passwords During a remote login, the device prompts you for a login name and password. You can display the login name when logged in to the device from a remote console by using a device status command. Logging in Remotely or Locally Logging in to a local console is the same as logging in to a remote console except that you must connect to the device by starting Telnet on your host system. To log in remotely, begin at step 1. To log in locally, begin at step 3. To log in from a remote console: 1. Connect to the device by starting Telnet on your host system. Your host system is the system to which remote terminals are connected. 2. Supply the device?s name or Internet Protocol (IP) address. To use device names, your network must have a name server. Issue either the device name or the IP address as shown in the following example: % telnet brandenburg or % telnet 128.185.132.43 At this point, it makes no difference whether you have logged in remotely or locally. 3. If you are prompted, enter your login name and password. login: Password: It is possible that there is a login and no password. The password controls access to the device. If a password has not been set, press the Enter key at the Password: prompt. Logins are not set automatically. For security, you can set up user names and passwords using the add user command in the CONFIG process. For additional information, see the add user configuration command, on 56. Remember to reload or restart to activate any changes. Note: If you do not enter a login name and valid password within 1 minute of the initial prompt, or if you enter an incorrect password three times in succession, the device drops the Telnet connection. 4. Press the Enter key to display the asterisk (*) prompt. You may have to press the Enter key more than once or press Ctrl-P to obtain the * prompt. Once at this level, you can begin to enter commands from the keyboard. Press the Backspace key to delete the last character typed in on the command line. Press the Delete key or Ctrl-U to delete the whole command line entry so that you can reenter a command. See ?Command Completion? on page 20 and ?Command History? on page 23 for more information. You can also use local Telnet commands on your Telnet client to close the Telnet connection.
Jan 21, 2007 | IBM NWAYS Router 2210 Model 12E
Extreme Networks Altitude 350-2 (15939) 802.11a/b/g Wireless Access Point Logo
162 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
