Hi, When I click Start/Run/dxdiag on my windows screen, I get this message in a window called DxDiag Error: "Error: Problem getting extra sound info, result code = 0x80070057 (Invalid Argument(s))". My DirectX Version is 9.0c (4.09.0000.0904). My soundcard is : Asus Xonar D2X PCI-E. Is there a way or two to fix this error? Thanks again.
  • 1 more comment
  • alainp9012 Nov 19, 2009
    Hi Marked,
    I've Uninstalled the sound card and restarted the computer then took a look at dxdiag to see if error message was there...yes it was.. But notice that I didn't reinstall the sound card yet. Should I? Then check again the "dxdiag"? Tell me what you think, Marked.
  • alainp9012 Nov 21, 2009
    Hi again,
    I've reinstalled the sound card drivers, but to no avail. I've also checked for new drivers with "Driver Detective" but none showed up. Now what? Plan B, if there's any? Thanks for your help in advance, Marked.
  • alainp9012 Nov 22, 2009
    I did what you were suggesting, same box appears. I also checked for conflicts but no conflicts were found. Do you have any other plans to remove that annoying message?
  • 1,959 Answers
This error indicates your soundcard is not configured correctly as the default device. This can happen if you've got an onboard soundcard as well as an additional soundcard. To fix this do the following:
  1. Click Start, click Run, type mmsys.cpl in the Open box, and then click OK.
  2. Click the Audio tab.
Once there, you will see all available soundcards. Select the one you wish to become your default (or the onboard card if that's your only soundcard). Then click on OK and restart your computer. You should find that the error has gone away.
Posted on Nov 22, 2009
  • Greg Margossian
    Greg Margossian Nov 23, 2009
    Apparently this is a common problem with your MB. The problem is there's a conflict with the recommended driver for the soundcard. A workaround is to install a different audio driver (Essence STX). Below are links for proven results:
    Vista
    XP
    It's a shame Asus doesn't provide adequate support for this problem as evidenced in their own forum.
  • 2,567 Answers
Try uninstalling all device drivers for your sound card from Add/Remove Programs applet in Control Panel, then make sure all audio devices for your sound card are removed from Device Manager.
The next step will be to reboot the computer. When it starts, it will detect your sound card again & prompt for the drivers. After the drivers have been installed, your problem will be resolved.
If this does not work, try to make sure that your sound card is not experiencing any resource conflicts with other hardware, by checking the properties of your sound card in Device Manager. If you find any resource conflicts, determine which resource is having the conflict (IRQ, DMA, I/O Memory Address Range), then manually assign your sound card a free resource. The list of free & non-free resources is available through dxdiag.
  • 6,487 Answers
You can go to device manager and uninstall your sound card from there, To open device manager Right click Mycomputer>Properties>Hardware tab> Device manager and once you're there look for the Asus Xonar D2X and then right click on it and click uninstall and after that restart the computer and that should correct the problem......
Posted on Nov 18, 2009
  • Mark Gil
    Mark Gil Nov 20, 2009
    Yes you need to reinstall the soundcard and if possible check if there's any updated driver for you and better use that in reinstalling the sundcard....
  • Mark Gil
    Mark Gil Nov 22, 2009
    Dont use driver detective in locating updated driver, better if you go direct to the sound card manufacturer web site and check it from there and manually load the updated driver....
Download sound card intel inside pentium
Find out what motherboard you are using by running dxdiag and then use google to search for your motherboard drivers.
1: click start
2: run
3: dxdiag
then a window will come up with a lots of writing about your motherboard and just concentrate on the part that has your motherboard description. Now you can google the drivers
Mar 18, 2014 | Computers & Internet
I dont know the size for id card
Try to run dxdiag tool to know the exact information about your pc hardware .
To run Dxdiag:
For xp: Press WIndows key along with r, this will launch the run command.
Now type Dxdiag and press enter system will ask for your permission press yes and all your hardware configuration will be in front of you.
For W7 and wista simply type the dxdiag in the start menu and enter.
You can get your graphics card details in display sec of the dxdiag.
Apr 07, 2011 | Corel DRAW Graphics Suite 12
WHEN I START PLAYING TOTAL OVERDOSE IN MY WINDOWS XP A BLACK SCREEN APPEARS AND SHOWS "OUT OF RANGE:" PLEASE PLEASE HELP ME
yes minamino kitagami is right,
goto start menu ,
select Run
type in "dxdiag"
DirectX Diagnostic Tool will run
then click at "More Help"
you will see there Override tab in last just click it
after that "Refresh appears"
set it from default to override rate "60"
now exit.
and play the game enjoy.
Mar 21, 2011 | SCi Total Overdose for Windows
The images i load for setting as a wall paper is stretched one and it is too big for the screen.How do i make it a portrait size
Try downloading this program to resize your wallpaper. Generally on Windows you simply right-click an area on your desktop and click :properties" to configure your background. The simplest thing to do is find your screen resolution and do a [Google] search for example: 1440 x 900 3D landscape, Define what you nedd and match your resolution. In WinXP just click the start icon and click "RUN", Copy and paste this command into the run box: dxdiag.exe a window will appeaar and you click "yes". When the new window opens click "Display" then scroll down to "Current Display Mode".
In Windows 7 and Vista click on the start icon and type the dxdiag.exe command into the search window and it'll appear in the above menu. Double click that item and proceed to find your resolution as stated above.
Hope this helps,
Nate P.
Jan 12, 2011 | Computers & Internet
When I start IGI i get : (fatal error: Couldn't flip DirectX error
i am usin a nvidia vga card and windows 7 64bit version
when i try igi it shows a error message couldnt flip
directx error
how can i fix this problem??????
Nov 11, 2010 | Computers & Internet
Sounds and audio devices
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Nov 08, 2010 | Microsoft Windows Vista Home Premium with...
Sir i am getting audio drive problem i am geeting error some 00x0000211 niceguychanti@gmail.com
Click on start menu
Click on Run
Type dxdiag, enter
Oct 28, 2010 | Microsoft Windows XP Professional With...
No sound
try this steps: 1. click windows button bellow 2. click run 3. type dxdiag then hit enter. (dxdiag is a diagnostic test to find out if your sound system is working properly. 4. after you launch the dxdiag in your system and there will be a dialog box appear in your screen, just click YES button then your done then after clicking the YES button the dxdiag box appear in your screen. 5. wait while the dxdiag box loaded it jurisdiction as shown below the box. then when it's done just click the next page button below. 6. To know if your system has a sound. simply click the sound button on the upper side of the dxdiag box. then click the Test DirectSound. when you click the specified button there will be a dialog box again but just click yes to play the sound but take note you should have speaker or a headset to hear the sound. 7.For more (you can install a sound driver for back up). God bless and I hope this step will help you in your problem.
Oct 25, 2009 | E-Machines eMachines W2686 PC Desktop
No sound through laptop speakers
you can do the following checks:
1.
mark the Volume icon in the systemtray and right mouse click, select the first entry and check if the mute checkbox is checked, if so uncheck it.
2.
Go to start, configuration, select sound and audio icon,
On the first tab, do you see your speakers?
Check your advanced speaker settings.
3.
set windows audio to automatic
click Start -> Run … enter:services.msc
Click OK, a services window will appear, scroll to windows Audio, double click
Windows Audio Properties will appear. Change startup type to “Automatic
First click Apply, then click on start to start the service
4.
Test direct sound output:
Go to start, run and type dxdiag in the box, hit enter.
(be patient it can take a while ...)
in the dxdiags window select the sound tab, you will see the information about your driver and you can test your direct sound.
Hope this solves the issue
Aug 28, 2009 | Line 6 Computers & Internet
Get graphics error installing Barbie Fahsion Show
To check the DirectX verison you need to access the DirectX Diagnostic Tool, follow the below mentioned to access the tool.
Click "Start", click "Run", type "dxdiag.exe" (without the quotation marks), and then click "OK" or press the "Windows Key" and "R" (The "Windows key" is between "Ctrl" and "Alt" keys on your keyboard) and in the "Run" box type in "dxdiag" (without the quotation marks) and then click "OK".
In the DirectX Diagnostic Tool the DirectX Version can be found in the "System" tab (third line from the bottom).
Nov 15, 2008 | Vivendi Universal Barbie Fashion Show for...
Computers & Internet Logo
217 people viewed this question
David Payne
David Payne
