Question about HP Officejet Pro L7480 All-in-One Multifunction Inkjet
Says there is a paper jam but there isnt - have looked and looked - can I overide it?
    President:
  • 995 Answers
Possible problems:
- Tiny paper or something is stuck in your printer.
- Your printer roller may have dirt on it.
Solutions:
-There may be a very tiny bit of paper stuck somewhere - look very carefully. Also, open all areas and then close them - sometimes a printer has to have that before it resets from a jam. Check your paper to see if it is being grabbed by the rollers. if they are dirty or worn, the paper will not catch and the printer thinks it is jammed. wipe the rollers with a bit of alcohol on a paper towel (barely damp) if that is the case.
Posted on Nov 18, 2009
#1 - thank you - this solved my paper jam problem
Posted on Nov 25, 2009
    President:
  • 3,085 Answers
In the rear of the printer there should be an access door. Open it and check for paper.
Ok my Epson stylus NX110 isnt working like it was yesterday now the paper gets stuck half ways i mean i can hear the printer still running and all but the paper doesnt roll down???? what should i do???
  • Turn the printer off.
  • Please inspect the paper paths and look for any stuck papers which may cause paper jams.
  • Look through the feeding tray and remove manually any visible stuck papers.
  • Turn the printer on and print.
Hope this helps.Thanks!
Sep 29, 2011 | Epson Office Equipment & Supplies
The printer is now saying paper jam and there isnt one
Open the back door pf the printer and look for a black plastic lever.That the paper sensor wich may be damaged and it is saying to the printer there is a paper jam.
Nov 01, 2010 | HP Officejet 6500 Wireless All-in-One...
Copier keeps jamming- prints a page but it jams on the inside. Looks like an accordian. I can open the side door, and pull out the jammed piece of paper.
It either needs a new fixing unit, or there is something stopping the paper on the paper path. Check and see if you can see anything obstructing the paer path. The fixing unit is what melts the toner to the paper, it is usually a consumeable option that isnt too hard to remove and replace, but can be pricey on some models.
Apr 13, 2010 | Sharp AL-1551CS Copier
Says paper jam but there isnt one
off your printer and manually feed paper by turning roller as guide, observe if sensor key freely move when paper pass, some sensor key stock when forcefully remove the jam paper inside.
Apr 05, 2010 | HP LaserJet 1020 Printer
Problem with paper jam, but no paper..
1) there should be problem of interference of another signals.
Apr 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Mar 21, 2008 | Samsung ML-2550 Laser Printer
Printer says "Remove paper jam"
check that the paper tray is set to match the paper your printing - look also in the printer driver settings for the correct size. A4, Letter etc.. If that did not fix it make sure the paper take-up roller isnt worn.
Jan 20, 2008 | Office Equipment & Supplies
Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Dec 06, 2007 | Canon imageCLASS D780 All-In-One Laser...
Paper Jam
you may have broken the paper sensor lever or all of the paper isnt out
Nov 07, 2007 | Dell 922 All-In-One InkJet Printer
HP Officejet Pro L7480 All-in-One Multifunction Inkjet Logo
213 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
