Question about Cell Phones
The display from my SonyEricsson is dark. You can see the screen, but you have no backlight. I have changed the display, but I have always the same problem. The external display ist functioning fine, when I close the fone. Opening the exsternel display switch off, but the maindisplay still is without backlight. Does somebody know this problem?
How to fix broken TFT background lighting?
I tougth it is better if you replace your TFT in one package. Too much time to be cost if you try to fix the backlight. But you can try this video http://www.youtube.com/watch?v=w4v20PyomuU after you sure that your backlight is the problem by installing another undefected TFT
Aug 15, 2014 | Samsung R65 Notebook
My tch843 screen goes dark after I power it down then try to re start. If i go to a dark room i can see the icons its the same on a.c. or batt. I went to settings and change screen britness to 3 or 4 and...
You have a bad backlight or inverter. The purpose of the inverter is to turn on the backlight. I suspect it's a bad inverter because that is a common problem on most LCD displays and you mentioned it turns on briefly - the backlight lamp is likely good..
Feb 24, 2011 | Mach Speed Trio TCH843 MP3 Player
My screen is on the dark side.my battery is okay.i am on ac power.how do i get my screen to lighten up? thank yu
if screen appears to dark, and u can see display in dim,
all u have to do is, change the backlight of lcd screen.
if ur in UAE, contact me3
Sep 24, 2010 | Toshiba Satellite M35X-S163 Notebook
Pioneer GEX-INNO2BK XM Radio Receivers backight problem
Have you tried changing the backlight controls in the menu? Pull up your menu, go to settings, then preference, and change display. Choose backlight display. You can put it always off, always on, or on for however many seconds.
Jun 05, 2010 | Pioneer GEX-INNO1 XM Radio Receiver with...
Laptop screen blackens - I can just barely see the images on the screen (nothing readable) - am able to use computer through toggle display feature. On shut down the laptop screen flashes with normal...
There are a couple of issues that this could be. Most likely the inverter for the screen is failing. The inverter takes the DC current from the AC adapter and converts it to high voltage for the backlight. If this starts to fail, it can mo lonher regulate the proper voltage for the backlight and the display goes dark. The only other issue would be that the cables attaching the inverter to the screen are chaffed from rubbing up against the hinge points and need to be wrapped and re-routed to avoid chaffing and pinching.
Jan 24, 2010 | Compaq Presario M2000 Notebook
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
NC2400 screen flicker
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | HP Pavilion zd8000 Notebook
Screen dark, but intermittant. Is it backlight, inverter or other
I always start with replacing the inverter since it's much much easier and is usually the source of these problems.
If that doesn't work you could replace the backlight ( not fun or easy for a novice) or replace the entire lcd.
Best of luck!
Jun 13, 2009 | IBM Lenovo ThinkPad X40 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 07, 2009 | Acer Aspire 5040 Notebook
Dark screen
contrast or brightness problem.
Dec 08, 2007 | Toshiba Satellite A20 Satellite A25 Series...
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
