Question about GE GBS22HCP Bottom Freezer Refrigerator
Fridge problem Help!!! The fridge tripped a GFCI. When plugged into a regular outlet the inside light comes on but the compressor does not kick in. Help!!!
    Problem Solver:
  • 17 Answers
You may have a short some where in the fridge. If you have a multimeter, I would suggest metering the power leads to the compressor. The compressor may be bad, if you find no shorts in the metering of the power leads.
Posted on Jan 10, 2008
I have an LG refrigerator freezer model number GR-S392GC that keeps tripping the power box. I plugged the fridge into another source but it kept shorting out. I isolated the issue to the harness wire...
the concept for a DRYER is the same for a washer or fridge in some instances
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Mar 28, 2015 | LG Refrigerators
REFRIGERATOR KEEPS TRIPPING THE GFCI OUTLET
A GFCI detects shorts in an electrical system and isolates power to prevent that device from harming other components upstream. GFCI's do go bad so that possibility exists. However, I would recommend trying to plug in your refrigerator into another outlet in your kitchen that has a different GFCI plug. If it does not trip then the GFCI needs to be replaced. If you do not have another available GFCI outlet and you plug it into a regular outlet, your breaker for that service line MAY trip. Better off testing with another GFCI. If your second GFCI trips, then the problem is with your refrigerator...meaning you have a short in your refrigerator. If you think this is something you can troubleshoot...BE CAREFUL!!! Always unplug your refrigerator before going into the components of the refrigerator. One thing you can do is turn both the freezer and refrigerator temperatures OFF or to their lowest setting. Plug your refrigerator in and see if the GFCI trips. If it trips you have a major short...probably in the bottom of the refrigerator. If it does not trip, turn the freezer temperature on first and see if it will run without tripping the GFCI. If it runs, then turn the freezer temp OFF. Then repeat the process testing the refrigerator components. Ice makers have been known to generate shorts in the system as well. There are various ways to troubleshoot a fridge. If you do not have the required electrical troubleshooting skills then PLEASE call a service technician.
Nov 30, 2017 | Jenn-Air Refrigerators
Kenmore Coldspot 25ssa. After power outage the refrigerator trips breakers and GFCI
Either the compressor or the start device on the compressor is shorted out. More than likely the compressor, hate being the bearer of bad news
Jun 07, 2012 | Kenmore Refrigerators
I have a samsung RS21DCSV And It keeps tripping out the power But when I Disconnect the 2 conectors on the compressor it stays on what is my problem Cheers and Thanks Clive!!!!
If it's popping the reset button on a GFCI outlet, I would recommend rewiring the outlet with no GFCI. Your compressor has a small leak to ground. The cost to replace the compressor is $500+. It should work fine with no GFCI. A good test is to plug it into an extension cord that is plugged into a regular outlet.
Mar 06, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Our refrigerator keeps tripping the gfci outlet it is plugged into in our garage. After several days we tried it again, and it worked for a while before tripping it again. We cleaned out the bottom...
first thing to do if it is continually tripping is to replace the gfci. they do go bad over time. Shut the breaker off to it. remove and note which wires go to which screw. if it gets wired wrong because going by memory. tis not fun trying to figure it out.
Best of luck
hope this helps and solves it. It should, if not call a tech for the fridge. or post model and make and we can go from there.
Jan 07, 2018 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Refridgerator freezer pops GFCI outlets
most gfci are 15 amp draws
its quite possible your refer needs 19 or more to start
i would reccommend getting the unit of gfci plug
Oct 12, 2009 | Refrigerators
When I plug my freezer to an outlet not gfi protected it works fine, but when I plug it into an outlet that is gfi protected it pops the breaker. I dont understand why.
All fridge and freezers should be plugged into an NON-GFCI protected outlet, since the inital start of the compressor can cause the GFCI to detect a millivolt surge, when the compressor starts, causing the GFCI to trip.
If this is in a kitchen, you should change out the outlet to a non-GFCI outlet BUT only to a single outlet that only has the freezer plugged into.
If it's in a basement, garage, or some other place with a GFCI outlet, you can change out that one outlet to a standard single outlet device of which ONLY the freezer will be plugged into and remain code compliant. You will need to make sure that any other outlets served by that current GFCI outlet stay protected, by installing the GFCI you swap out, and put it in place of the NEXT outlet in the circuit.
By doing that, you will have the first outlet that was the GFCI, now a single outlet NON-GFCI serving the freezer, but the next outlet in the branch circuit gets a GFCI outlet, thus protecting the rest of the circuit, in compliance with the NEC (National Electric Code)
If you need further help with this, please comment back and I'll check back later and provide you more detailed info. Of course, be sure to turn off the breaker to this circuit before making any changes to the outlets, etc.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | GE Freezers
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
GARAGE FRIDGE STILL TRIPPING THE GFCI ....WHY?
If your frig is plugged directly into a GFCI, you need to remove the GFCI and replace it with a standard plug. No one should have a GFCi behind a refrigerator.
Jan 23, 2008 | Maytag MSD2756G Side by Side Refrigerator
GE GBS22HCP Bottom Freezer Refrigerator Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
