Tv screen just went black, blue on light stays on, flickers when changing any command.
  • 5,138 Answers
Post your model n brand name It will be on back of TV then I can help!
Posted on Nov 18, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Screen goes black
reboot using the key HOLD the key CTRL +F11 OR F12 depend of your computer model use restore factory default. or reboot using disck or USB.
Other wise restart HOLD the key CTRL+F8with network, and use the CHKDSK command for repair.
God bless you
Jun 23, 2013 | Toshiba Satellite P305D-S8829...
No picture on intermittent basis -
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 27, 2012 | Vizio GV47LF Television
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
37" Polaroid HD LCD black display but appears to be "on"
The power supply board was having problems before.That the board,where the power a/c cord plug into it Now might also the Tuner board are dead too.The tv Tuner board,that the board where the tv broscast signal cable plug into it.That the Tuner board.Tries Websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement to see if solved the problem,not probally will have to buy the refurbish Tuner board for the replacement too.
Jul 13, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Screen went black
Remove the front grey bottom panel of you TV (don't forget the 2 screws behind the front AV cover located just below the power button) then remove the panel behind the grey panel. You should see 2 heat sinks on the front right of your TV, place a fan near your TV and have it blowing on the heat sinks. Now turn on your TV and see if it stays on longer then it has been. If it does, your DC amps might be overheating. If they are, you might be able to fix your problem by adding in a little more heat sink compound between your DC amps and the heat sink itself. You can find the compound at Radio Shack for about $5. let me know if pointing a fan directly on the heat sinks helps.
Jul 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at macry2121@aol.com
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
WEGA 36" : Screen is low contrast and green
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Jan 02, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
